Question about OEM Systems I-Cam 330 Webcam
Hello i do need a chicony dc3120 driver for win 7 64 bit os system thank you
I used twinkle cam successfully in windows xp. I have upgraded to windows 7. How do I get the driver or will anything work?
According to http://www.chicony.com.tw/download/di/driver.asp , the available drivers were written in 2004. Chicony has stopped supporting their cameras for newer Windows OS versions. I suspect they never made a 64-bit version of the driver for XP 64-bit.
If you had the 32-bit version of Windows 7, you might be able to use the compatibility mode to install the driver. To check your version, click on Start > Control Panel > System and Security > System. Look for your Windows version and check if it says x64. If you see that in the description, you have the x64 bit version. Otherwise, right-click on the driver file from the above site (after extracting the files from the zip file). Choose Properties and the Compatibility tab. Check the box for always Run this program in the compatibility mode and set it to Windows XP in the drop-down menu. You may need to repeat this on the camera software as well.
If you have a 64-bit version Windows Home Premium, you may be better off upgrading to Windows 7 Pro or Ultimate. Then you can download and install Virtual PC and the XP mode, if your hardware can handle that software. This gives a virtual version of the 32-bit version XP that will run your camera. (The CPU needs to have virtualization support and it has to be enabled in the BIOS. Then you need enough memory to give the virtual XP at least 512MB -1GB of memory.) If you already have Windows 7 Pro or Ultimate, just use XP mode. Other virtual PC software exists but they require a licensed version of XP. (If you can find a valid license.) The only issue I've found is that files saved to the C: drive in one OS can't be accessed by the other OS. You have to transfer the files with an external drive, flash drive or burn the file to optical disc.
Dual boot systems with XP and Windows 7 can be set up if you have the XP license. Then pick the OS you need when you boot up the computer. This requires you to repartition the hard drive or have two bootable hard drives. Make sure to back up before partitioning the drive.
I wish that I had better news for you.
Aug 22, 2013 | Chicony TwinkleCam DC2110 Webcam
Hello sir i will using mron webcam shorp view please i wnat mron webcamera software and drivers for windows 7 64 bit link please send my email id vijaikumar2002@gmail.com thanking you
try here http://www.fileguru.com/apps/mron_clear_webcam_driver.The device manufacturer stated this product is not compatible.with win 7 32 or64 bit os.
DT
Jun 11, 2011 | Computers & Internet
I need driver for my printer hd officejet 4255 for win7
You may be able to find it on the HP WEB site.
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
May 31, 2011 | HP OfficeJet 4255 All-In-One InkJet...
Drivers chicony dc-6120
Hi nicacristian, to "Update the Driver / Software."
Go to this "Website Link," below.
Fill-in all information required.
Ie: Brand Name, Model #, and Operating System...
"OS" are: XP, Vista, and Windows 7
Scroll-down, and select the [Drivers] you need from the "List."
"Download the Drivers."
!"Take a moment to rate the help."
Thanks paul7of9
Click here: http://www.chicony.com.tw/download/kb/top1.asp#
Mar 21, 2011 | Computers & Internet
Hi! i need hp 3325 driver for windows 7, tq.
Click here Click on above link and download driver for your os and install. Let me know if you need further assistance. Thanks for using FixYa.
Feb 03, 2011 | HP DeskJet 3325 InkJet Printer
I want to run Win Server 2008 Enterprise edition on Dell Optiplex 360. I need the drivers for: NIC, Audio, Video. Thank you
Verify that your hardware is compatiable to the Server NOC. (Most are 64-bit software which require 64-bit compatiable software. When you place the server dvd/cd in the 1st time, it will check your system to make sure it meets the minimum requirments for install. If you already have the server os installed, You have 2 chioces: 1. Microsoft Server drivers (Microsoft support) or 2: Download each vendor's drive to your system or portiable drive and install as the server os is installing. (it will ask for 3rd party drivers at the start of install.
Good Luck
C2Solutons
Jan 22, 2011 | Dell OptiPlex 360 Desktop Computer
Hello, My laptop model is y410, now i instal os in windows 7 32 bit after i instal NVIDIA VIDEO SUPPORT DRIVER this is not instal in my laptop final thic say instal locate folder in not available in...
try to download driver that support the video driver (win 7 driver for nvidia ) or you can locate the xp driver on your hard drive than click ok
Jan 16, 2011 | Lenovo 3000 Y410 Laptop
Looking for Canon LBP 3200 driver for Win 7 64 bit OS. Thanks.
Hi
this printer is not running under Win 7 64 bit OS
replace printer or use onter oparating system
Pls vote us to keep us alive
Nov 25, 2010 | Canon LBP3200 Laser Printer
Is lexmark 2350 all in one printer compatible with windows 7
I'm sorry, but the Lexmark 2350 is not compatible with Windows 7.
I checked some driver links, it Lexmark released some drivers for the supported operating systems like: Windows 2000/2003, Win XP, and Win Vista 32-bit and 64-bit OS.
If Windows 7 is supported, Lexmark will surely release a driver for this OS.
Thank you!
Jun 12, 2010 | Lexmark X2350 All-In-One InkJet Printer
Hello. need an driver or so for Intel 82801 GB
depends what O.S. you have win xp 32 bit then from here http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=ca&dlc=en&product=3201120&lang=en#
Dec 14, 2009 | Computers & Internet
Computers & Internet Logo
602 people viewed this question
Top OEM Systems Computers & Internet Experts
micky dee
Terry Hair
Bill Boyd
Are you an OEM Systems Computer and Internet Expert? Answer questions, earn points and help others
