My hard drive doesn't boot up as normal. When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps. Numbers 3 and 4 on the hard drive are lighting. The monitor is switched on but there is no picture. I tried another monitor with my hard drive and that worked fine, so it is definitely a problem with the hard drive. What do you think the problem might be? Please can you help me! It's a matter of life or death!
  • Computers & ... Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 29, 2010
Air con switches of when on heating then starts beeping 1beep 2beeps 3beeps
Some units emit a flashing code. Check your manual to see if the flashes represent a fault code.
Apr 22, 2014 | LG Heating & Cooling
Taken out cmos and ram sticks,switched on and still gives 3beeps,3beeps,1beep
Try to change your RAM . Or if u have more than 1 RAM try to isolate the problem by putting in the 1st stick then try to boot it up. Hope it helps
Nov 22, 2013 | Fujitsu AMILO Pro V2055 PC Notebook
Phoenix bios
Are you sure this isn't a 4 beat sequence? such as 2-1-2-1?
Nov 22, 2013 | Fujitsu Siemens Amilo Pro V2055 V2030...
3 beeps 3beeps 1beep
The beep codes indicate the battery is discharged - and needs to be recharged. A manual can be downloaded at http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/LIFEBOOK/AMILO/AMILO-Pro/Downloads/a26391-k183-z121-en.pdf
My WD2500BEVT beeps (3beeps pause 3 beeps pause) a number of times then sounds like windows recognizes the drive but does not.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
hope this helps
Dec 30, 2010 | Western Digital WD Scorpio Blue WD2500BEVT...
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
When i on my pc normally 3beeps but i only heard 1beep and nothing shows on the screen
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Oct 08, 2010 | Acer Computers & Internet
Computer problem
during these beeps there should be pause between them at some point...in other words you may get 2 beeps/pause/1beep/pause/2 beeps noting the number of beeps and where the pauses are will help. From what you are describing and without more info it sounds as if you are describing beep codes, and they generally can give us a lot of information.
Aug 09, 2009 | Computers & Internet
When I turn the hard drive on it beeps 6 times intermittently and doesnt boot up as normal. The monitor is switched on but there is no picture. I tried another monitor with my hard drive and that worked...
Unplug power from the machine for a period of 5-10 minutes.
Plug it back in and attempt to boot. Carefully notice if there are any beeps again, and listen for pauses in between. Dell beep codes go in a three pulse pattern I.E. 4-Slight Pause-4-Slight Pause-2-Pause/ and repeat.
After this, you may have to open your machine and assure that everything is well connected.
There is a chance however that a major system component has failed and needs to be replaced.
Hope this helps.
Apr 13, 2009 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
