Question about Microwave Ovens
New World satin Steel E600 all hob rings on full power. Controls have no effect on heat settings.
  • 1,557 Answers
If its heating at all then its a primary control problem if there is no heating of food at all then the magnatron has birned out and needs replacing the part is worth more then the whole microwave replace the microwave
have a great new year
sonic boom electronics
Posted on Dec 29, 2010
Tip
MICROWAVE POWER TEST Hi Everyone, In this tip I will show you how to easily test...
Hi Everyone,
In this tip I will show you how to easily test your Microwaves power. If it is sufficient, or if it is not heating effectively anymore.
Non heating Microwaves are a common issue, and the most likely component that is faulty is the Magnetron - These days Magnetron's are quite expensive (usually about 50% the price of a new Entry Level Microwave). Low heating could mean a Magnetron becoming faulty (unlikely, as a Magnetron either works, or it doesn't work)
Tools required: A Normal Glass (Heat-resistant, in other words Microwave friendly), Water (Room Temperature) , a Centigrade Thermometer (Can get this at any Pharmacy)
Procedure:
1) Fill a glass with approx. 125 ml water. Use water at room temperature (from the tap), avoid using refrigerated water as this will work against the test we are doing.
2) Measure the initial temperature of the water with the thermometer (It should be between approx. 10 & 20 degrees).
3) Place the glass with the water about 2 cm away from the center of the Microwave Oven plate.
4) Heat the water at full power (The highest setting possible on your Microwave) for 70 seconds.
5) Stir the water (For 5 - 8 sec).
6) Measure the final water temperature with a thermometer.
7) If the increase is 45 degrees or more, then your microwave is heating sufficiently, if not it could mean replacing the Magnetron, or purchasing a new Microwave.
I hope this guide as helped you. If it has, please rate it accordingly.
on Apr 23, 2011 | Microwave Ovens
I have a Defy Gemini Petit Chef oven and glass hob combo. On e plate on the hob appears to heat up to maximum temp irrespective of the setting on the control. The other plates seem to be fine. Is there...
If it is a "Hot Plate" then the thermister is probably within the plate and replacement of the plate may be required.
Call a qualified appliance repair person for an estimate of the cost to repair.
Mar 23, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
MW1030WA 1000 Watts Microwave Oven: Not getting full heating effect. Heating effect re...
If there are no bangs or arcing taking place and simply the heating output is slow, then it would be a matter of replacing the magnatron. Once the micro cover is removed,the magnatron is that square module sitting half way up bolted on with 4 small screws. Quote the model on the sticker stuck on the MAG. and order a new one. Take care when replacing. Lage voltages present on capacitor.
May 18, 2010 | Samsung MW1030WA Microwave Oven
Microwave is just over 1 year old and has stopped heating things
Most micro's have a % heat setting. Make sure that you are at 100%
Jul 21, 2009 | Microwave Ovens
We purchased a Frigidaire cooker, electric oven, propane gas hob. It seemed odd that the hob rings take ages to boil a pan of water, cooking with oil is extremely difficult as it takes way too long to get...
Is this a mistake? It's impossible that nozzles didn't helped...? Just impossible.
Or was this problem posted before our chat session..?
Either ways Do Not hessitate to Contact us on fixya
Good luck with your cooker, and HAVE A NICE DINER
Jun 24, 2009 | Microwave Ovens
Microwave Ovens Logo
87 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
