Question about HP LaserJet M1522n MultiFunction Printer
I can not set my hp m1522nf printers for fax, I can not received & sending any fax. pl. solve my problem. Thanks,
    President:
  • HP Master
  • 2,022 Answers
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Posted on Dec 29, 2010
How can I send fax to pc?
To solve this problem, follow the link below and follow the instructions on the linked page on how to solve this problem. For me to give you instructions here, it would be too long so I set up this link that will take you to solve the problem you're having http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=c01315105&prodTypeId=18972&prodSeriesId=3442750
Aug 27, 2011 | HP LaserJet M1522nf Multifunction Printer...
Hello I ve got 2 hp M1522nf printer and they have the same message: err. scanner 5 Can't print anymore send faxes...Do anything.
Hello, The scanner is failing to initialize, this is a common problem with this printer. The printer will also randomly power itself down, Good news it can be repaired, Follow the link for more information.
M1522INFORMATION
Thanks
Nov 15, 2010 | HP LaserJet M1522nf Multifunction Printer...
Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Jul 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
Data sending to fax fax to not recvied
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Feb 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
I have a hp 2200 all-in-one printer. For some reason it will not receive faxes . I tried to send a fax from work to my home fax & I got a no answer error. I tried calling the number & all it does...
For that you have to enable auto answer in your printer.
For that go to printer menu settings there you find option for enable auto answer in fax settings.
then it automatic receive fax.
Let me know if you need more assistance.
Thanks.
Oct 07, 2009 | HP PSC 2210 All-In-One InkJet Printer
Can I send a fax from my computer via the HP LaserJet M1522nf?
Yes you can send fax from computer.You need one dialup connection with Fax modem. then you need fax software. there are many software availble on the net . One is Mighty Fax. you can download it from the internet and many other you can search in google.
Sep 17, 2009 | HP Hewlett Packard LaserJet 3000dn Printer
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
HP LaserJet M1522n MultiFunction Printer Logo
297 people viewed this question
Seeker5211
Seeker5211
