This card is not officially
supported under Windows 7. You could try the ATI Catalyst Windows Vista graphics driver under Windows 7, but it's not officially
supported by AMD.
You might have to use EPSON FX Series 1(80) INBOX Driver*1
what *1 means - INBOX Driver is Printer Driver that is included in Windows 7. so all you need is to go to Control Panel - Printers and Scanners and
choose EPSON FX Series 1(80) INBOX Driver as your driver fot your
Panasonic printer. This advice was recommended by Panasonic, I have tried to locate the driver for Win7 but no luck I hope this works for you. Good Luck
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is
for other versions of operating system. I am also using windows 7 like
you so don't you worry, You can still use your old installer/driver from
other versions of operating systems. Just remember that before
installing any program in a windows 7 Operating System Computer, Use
"troubleshoot compatibility". Right Click the Icon of your program
installer/application first, then choose "troubleshoot compatibility". This will
allow you to choose on what type operating system your program will run.
Just reply back if it still doesn't work.:D rate and vote for me:))
Nova Development no longer supports Greeting Card Factory 5 on their website, but it looks like Greeting Card Factory 5 is only compatible with Windows versions up to Windows XP. You could try installing it in Windows 7, but it probably won't work right.
However, Greeting Card Factory 8 is fully compatible with Windows 7.
You need to change the camera's USB connection mode from "PC" to "Print/PTP" in camera setting menu. After that it should be recognized by Windows 7 without drivers.
Windows 98/2000/Me; 200 MHz Pentium or compatible; 64 MB RAM; Windows XP; 300 MHz Pentium processor or faster 128 MB RAM; Minimum 427 MB hard disk space; 800x600 display, 16-bit color;
Windows compatible mouse; Windows compatible sound card and speakers; Windows compatible printer (monochrome or color); Microsoft Internet Explorer 5.0 or higher
33.6 Kbps modem or faster and Internet service provider account required for Internet access, online graphics, online projects, and animated greetings
Encore/ RiverDeep
PC
This is system requirements "above" Vista and Win 7 are not supported.You would have to contact them for support.Sorry.
The issue is most likely that your sound card drivers as well as other things are not installed.
Take a look at the end of my windows 7 installation guide. The part about after installation, also note that you can use Vista drivers on windows 7 as long as the drivers are for the same bit version, 32bit vista drivers will work with 32bit windows 7, and 64bit vista drivers will work with 64bit windows 7
http://www.fixya.com/support/r3575598-step_by_step_howto_install_windows_7
The Company Internet Site at http://www.tdvvison.com/ is no longer available (877) US.VISON
There are lots of people that are having problems locating drivers. I suggest you look for a third party support driver or possibly some downloadable firmware. There is a company called "3 geeks and a mouse" that services and repairs the OLD TDV Vision Lappys. They possibly could provide you with additional support or suggestions. I hope this helps...good luck.
