The program for selecting a wash does not work. the water fills the drum and overflows
  • 784 Answers
Sounds like the water height sensor is bad, disconnected or blocked.
check the sensor line and the wires -- if all is clear and looks good,, I would say that it is the sensor itself. by removing the back panel of the machine - you should have full access to the sensor,wires and water height line ( the line will be mounted to the outside drum and go down to the sensor,,, the sensor is basically a pressure sensor ) --- again,, check the wires and make sure they are all connected proper, there is a chance that they shook lose during a cycle ( ? ).
c...
Posted on Dec 29, 2010
IT KEEPS FILLING UP WITH WATER AND OVERFLOWS
There is a tube next to the drum that senses the water level, take the screws out of the back of the machine near the top and then you can lift the top off over the drum, look for the tube and see if it is plugged with lint dirt or softener. Clean it out. If that is not the problem then check the sensor that it plugs into to be sure it is not bad
Jul 03, 2016 | Washing Machines
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Cycle stopping after filling with water on hoover oph 148
the heater may not be working or you have a broken wire
Dec 31, 2013 | Hoover Washing Machines
In the begining of was the water won't stop filling, it overflows and it won't go to the wash cycle (adjetate) however I can turn it to the rinse cycle and it will drained and spins?
Possible that the water level sensor has failed.Shut down washer and trace the sensor which is a pressure activated switch from the drum overflow. the switch can be activated by blowing and checking continuity. if so replace the unit
Dec 30, 2012 | Whirlpool Washing Machines
Wash cycle,spin dry, water level
I WOULD CHECK FOR A PLUGGED AIR PRESSURE HOSE OR THE PRESSURE SWITCH ITSELF.
Jan 26, 2009 | Hoover Washing Machines
Maytag W-7 Washer water fill does not stop
Yes, I think that rubber tube measures water level. But I've never changed one. Good luck.
Aug 02, 2008 | Maytag Washing Machines
Washing machine overflowing
I'd have a look at your water level detector to start with. Usually a narrow bore hose running from near the bottom of the drum to a pressure switch somewhere near the top of the machine. Most common problem is that the hose gets blocked with gunk. With the machine off and drained, try removing the hose and giving both it and the barb on the drum that it came from a good clean through. A.
Jul 17, 2007 | Kenmore 22442 Top Load Washer
Drum filling with water when machine switched off
what you refer to as the overflow cap is the cover to the filter which you should remove regularly and check. however nothing to do with your problem. the water could be coming from two sources: first, if the drain is plumbed in under the sink, water can flow into the machine every time you empty the sink. the cure is to put the drain hose up as far as possible in a swan neck. secondly, the intake water valves could be leaking and the only cure then is to replace them
May 04, 2007 | Zanussi IZ12 Front Load Washer
Wash starts it fills with water then stops and wont wash
problem may just be that drum is not turning so you think program is stopped. try cancelling and select spin program and see if you get spin
Apr 01, 2007 | Hotpoint WMA44 Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
