Question about Apex Digital LD4088 LCD TV
Why does the picture have a lot of shadowing?
  • 38 Answers
Because of the slimness
Posted on Dec 29, 2010
Nikon d-90, shadows in pictures
if you're using pop up flash, you'll get more shadows doing a portrait shot than a landscape shot just due to the position of the flash bulb and the angle the shadows are cast.
Jul 06, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
I have a vertical shadow about 1-2 ft in width running up the right side of the projected picture. The bulb was just replaced this year and the shadow didn't start until some time after the bulb was...
The light tunnel has collapsed. Google "infocus light tunnel." You can glue it, as I did, but it tends to break again. From what I have read nobody has a good fix and the manufacturer has ignored the problem which has alienated a lot of customers. They won't even sell a replacement tunnel. Good luck!
Dec 01, 2010 | InFocus X1 Multimedia Projector
Harsh shadows
to avoid harsh shadows moveaway from the bright light,or move object/people close to the backdrop that will reduce the strong shadows.
Apr 10, 2010 | Canon EOS Rebel XSi Digital Camera
Shadow on bottom of picture when I use a flash and 12 mm lens
Are you using a lens hood? That could create the shadow.
Nov 11, 2009 | Nikon D70s Digital Camera
Black and white negatives produce scans that show too much contrast......any suggestions?
1) Decide which problem is the worst: shadows too dark or highlights too light. 2) Run your scan with Nikon 4 software tool "Digital DEE" adjusted for EITHER Shadows or Highlights (not both; Highlights setting will "trump" a Shadows setting, even though you have a non-default setting at all DEE sliders).  Generally good choices for Shadows are 39 to 55. (39 = lighten the shadows a little; 55 = lighten the shadows a lot.) Experiment; do several scans. Generally good choices for Highlights are about 17 to 42 for amount and about 4 to 30 for threshold. (17/4 = dim the highlights a little; 42/30 = dim the highlights a lot.) Again, you have to experiment to get some experience. 3) When in Photoshop PSD format (After first doing a Levels adjustment): Try using the Adjustments/Shadows and Highlights tool to AGAIN brighten your too-dark shadows and/or tone down your highlights. (I.e., the effect is cumulative on top of your Digital DEE effect. But Digital DEE is a more "magical" feature and is somewhat preferred to PS's Shadows and Highlights tool. DEE, however, will often produce an annoying "light smear" [bright area "dragged" into an adjoining darker area]. In case of a "light smear" from DEE, do not use the tool; too hard to fix.  Use PS's Shadows & Highlights tool instead.)  4) Proceed with other PS adjustments such as Curves, etc.  5) Still not satisfied?  Go to Levels again and look at your histogram. Is it really "stacked" to one side or the other (a mountain way over at the left or at the right)? You might want to try the rather severe command of Adjustments/Equalize.  This "spreads out" your pixels more evenly across the histogram. Note: this is a scary adjustment that requires misc fixes to tone-down certain aspects of the Equalization adjustment.  No free lunch, right? 6) After experimenting with the above tools, you should be able to get a handle on too-contrasty pictures. There will be a learning curve.
Sep 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
Grey shadow appears in the centre of every picture.
probably not something is up have you ever had direct sunlight hit the lens maybe at the beach? Or lots of heat can damage the lens you. lens replacement is just the same as getting a new camera. hoped that helped.
Jul 03, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Apex Digital LD4088 LCD TV Logo
79 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
