Question about Spinmaster Air Hogs Xs Motors Blue Moto Frenzy Stunt Bike
My moto frenzy stunt air hogs bike wont work. The back wheel wont move he is not well & he wants it to work please help. It is just clicking it worked for one second on xmas day & now its stopped what a jopke these are its disgusting they should never allow a toy like this on the market another xmas dissapointment.
Same with mine
Posted on Dec 31, 2010
  • harrystonely Dec 31, 2010
    i suppose you could try changing the batteries to brand new ones....when that vit done plug the portable charger into the back of the bike and it should charge fully within 45 mins.....hope this helped. B)
Mini moto chain jumps off
Sounds like either the chain is loose (adjust tension by moving rear wheel/axle further to the rear), rear chain sprocket is worn, front (transmission end) drive sprocket is worn, or rear wheel is severely out of alignment with the bike.
Oct 07, 2013 | Bell Moto 9 Stunt Helmets, Bell
Tip
How to make the Spinmaster Air Hogs Moto Frenzy R/c Stunt Bike work.
If the bike isnt working properly, like short driving time and wobbly steering. lay it on the side with the screws pointing up, unscrew the 4 philips screws, the body is glued together so be careful, with a small flat screwdriver or a knife, bend the body apart along the crack going through the middle. Be extra careful in the lower front part because this is were the battery is placed. When the body halfes are separated, lay the half containing the elecronics and motors so you can axess the parts. Remove all dust and hair and othe forein matters. Take the rear wheel off and slide the tire off.With a small screwdriver press the three locking notches that holds the wheel togeather and separate the halfes. put a small amount of lubrication oil (thin oil) on the gyro axel inside the wheel and on the drive gear and spinn the gyro wheel so the oil gets in to the "bearings".Press the drive gear so it sits tighter towards the wheel (not too tight, it has to spin freely. Put the other half of the rear wheel back and spin the gyro wheel with your fingers as fast as you can. it should balance itself on a flat surface for atleast 5 - 10 seconds. if not put some more oil on the shaft, and try again. When finished dry of excessive oil and put the tire back. Take the dual gear that's in front of the rear wheel off. there is a small shim between this gear and the one that's still on the shaft. put some oil on the shaft and spin the shim and remaining gear so the oil lubricates the movement. put the dual gear back.Remove the wheelie gear ( the one with a stick lying under the bike) put a drop of oil on the gear axel that's underneath the wheelie gear. Spin all the gears so the oil can get inside and then remove the excessive oil with a tissue or something like that.The wheelie gear has a spring mounted on the backside, be sure to get this back right (the small ring of the spring shoul fit on a plastic pin in the body and the bigger ring on the cnter of the wheelie gear), and then put the wheelie gear back so it sits centered and conected to the second gear.Put the rear wheel back.Take the other body half and put a drop of oil on the gear shaft thats still in there, spin the gear etc.Put the halfes togeaher, be careful so you get all the axels and pins right and no wires between the halfes. squeese the halfes togeather and screw the 4 philips screws back. Put the driver back and charge the battery. Try it!!!
on Jan 13, 2015 | Spinmaster Air Hogs Moto Frenzy R/c Stunt...
How do you replace the propeller on the Air Hogs Sky Stunt, Blue?
To replace the Propeller on an Air Hogs Sky Stunt plane (I got this from their customer server number):
1.) Hold the propeller and turn the nose (at the grey plastic edge, not the rubber) counter clockwise (aka left) until the nose unscrews.
2.) Slid off the OLD propeller.
3.) Slid on the NEW propeller (You will notice there are slots on the propeller mount), need to line up the propeller with those slots.
4.) While holding NEW propeller, screw the nose back on (similar to step # 1) clockwise (aka right).
Hope this helps someone else.
Mar 15, 2013 | Toys
Moto frenzy rc bike. fully charged. rear wheel won't turn. front will go left/right.
I also had this problem during christmas. The bike worked only the first battery then the rear wheel stoped turning. The dissapointment was huge. And I read that there are a lot of people around that have the same problem. So I tried to fix it
The problem was a wire that was wound up in the main gear of the rear wheel. This wire cames from the inside of the bike, so I can imagine that a lot of people will have this problem.
So how to fix it?
It is quite simple to remove the wire parts from the gear. But it is not so simple to open the bike. There are 4 screws but when removing the screws and you try to open the bike it will not open.
The reason is that the gas cap on top of the bike is glued in. So i worked a little bit around of this cap with a stencil scalpel knife. But be careful right under the cap are the wires for the steering wheel. So dont go too deep. Once opened you can easy remove the rear wheel and the gear to find the ugly wire wind up on the main gear. In my bike the wire was directly in the small gear on the main motor. It took a while to remove all parts of this wire.
But once removed the wire the main motor will turn again.
Put all gears in the right places and close the bike.
In my case all things are fine after this repair.
Good luck
Stefan
Dec 25, 2010 | Spinmaster Air Hogs Moto Frenzy R/c Stunt...
Moto frenzy will not move. the rear tire will not turn. it is fully charged. only clicks.
Check the motor - it may have moved out of place or maybe lost a shim which would change the alignment. Be careful as the mount for the motor is plastic and could break easily.
Nov 03, 2010 | Air Hogs Thunder Trucks Motors Micro Rc...
Wont fly
I have an Air Hogs havoc cyclone stunt plane. I am not sure if your plane has this, but on my plane's remote there left and right steering trim buttons. Play around with these until your plane flies correctly.
Dec 30, 2008 | Air Hogs Glow In Dark Havoc Stinger Rc ...
Spinmaster Air Hogs Xs Motors Blue Moto Frenzy Stunt Bike Logo
291 people viewed this question
Top Spinmaster Toys Experts
ray gallant
TigerOCX
Level 1 Expert
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
