Question about NAD L73 DVD Player
I have humming problem with my NAD L73. It started
I have humming problem with my NAD L73. It started suddenly some months ago. The unit is 3 years now. Very strong humming when the unit is powered up cold and then gradually fades, but it never disappears completely. The humming level can vary from time to time without any changes in the setup or the system. I have tried eliminating all external sources of humming but my conclusion is that it is something inside the L73 that is not allright.
  • NAD Master
  • 19,396 Answers
Hi.
If humming disappears after the unit "warms up", then it is usually a defective component in the internal circuits. Components are used to stabilize the signal in different parts of the circuit, capacitors store charge, ICs and transistors amplify or stabilize voltage. Some of them have an active role only when circuit is 'cold' (capacitors are still charging up). A psu that is starting to fail because of a defective capacitor, a faulty preamp, or a defective amp final IC may result in a humming noise that disappears when the unit 'warms up'. If the problem is a defective component you usually get the fault worsening in time, until the unit is not starting anymore.
Before sending the unit for repair, check home network voltage and grounding, or test the NAD L73 somewhere else.
Connect the NAD L73 directly to the wall socket. Power draw from other appliances connected to a multi-socket extension, or grounding problems can result in humming.
Test using different cables and devices. Use a minimal set of connected cables when testing.
Check speakers or audio wiring and check the speakers.
If all this does not fix the problem, then the L73 must be repaired. In that case contact NAD Electronics.
Regards.
Ginko
Posted on Dec 29, 2010
Hi does any one no how to unlock Nad L73
1. Open the disc tray
2. Press PROGRAM
3. Press 2, 5, 1, 9
4. Current region should be displayed
5. Enter region (8 = codefree)
6. Press DISPLAY, turn the player off
Apr 20, 2012 | Audio Players & Recorders
About a month ago my speakers started humming-does't matter if the cable/dvd are on, as long as the receiver is on it hums. Figured out it was the receiver since I plugged other speakers into my...
normally a Hum is caused by a bad ground,, if it only happens when the unit warms up it could be the output drives are failing. , check the grounds to the unit first, then the wires to the speakers themselves, if they all check out ok,, you need to take it to a repair shop dealing with receivers
May 27, 2011 | Yamaha RX-V1600 Receiver
I've bought my NAD C326BEE amplifier almost two years ago, and i got promised a hell of a good quality and that it would last for YEARS. But ever since i bought the damn amplifier, it has been shutting off...
I'm also a Nad fan. I find this pretty odd that you should loose two in such a short space of time. The cutting out is due to the "protection circuit". I would be inclined to get your speakers checked out as if they are faulty or not "matched" to the amp, it will trigger the amp to "protect itself" and shut off.
Jan 07, 2011 | NAD C326BEE Amplifier
Hi Our H20 Mop is just over 12 months old and when we start it up the red LED light will not change to green nad will not steam up. When you run your hand down the machine you can feel a little bit of...
Hello
Our (POS !!!!) H20 Mop is just over 20 months old,suddenly became inoperative....
At startup,LED lites red,shortly thereafter changes to green,however NO steam out unit & an audable 'humming'
type noise comes from the unit.
Whatcha got ????
Alf
Oct 29, 2010 | Vacuums
Nad c270 power amp transfomer hum
if the hum is in the sound output you have a blown power regulator
Mar 31, 2010 | NAD C270 2-Channel Amplifier
2003 BMW 530i won't start; mechanical hum, but no clicking sound
my 530i are 203 and problem was iwash the car with watter and starting problem no start all light is vuzible
Jan 03, 2010 | 2004 BMW 5 Series
Intermittent dead ignition to dead ignition
This problem is usually caused by a failing neutral safety switch. Try moving the shifter when it is dead. Will it start in neutral? Move the shifter while trying to start (foot on brake!)
Jul 14, 2017 | 1991 Acura NSX
NAD S300 Amplifer humming
You have either got a bad earth connection, or possibily there's a capacitor failed.
If you can't find a dodgy conection, I would replace the large Electrolytic Capacitors in the power section, they are used to take out 50hz hum in the mains electric, when they go you get that hum coming into your system.
Nov 15, 2009 | NAD S300 Amplifier
NAD 370
try to re-set mini circuit breaker inside.
Jan 21, 2008 | NAD C370 2-Channel Amplifier
NAD L73 DVD Player Logo
222 people viewed this question
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Raj Patel
 Grubhead
Grubhead
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
