Question about Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button...
Westinghouse Freezer FJ 383 M-L - The contents are thawing. We have removed the contents and increased the temperature control. The motor has been running for over 24 hours and the temperature in the compartment is 0C. The panel towards the bottom of the freezer, where the drain is, is frosted over.
aborcass
  • 2651 Answers
SOURCE: fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Posted on Mar 22, 2008
lenwest
  • 150 Answers
SOURCE: Frost Free, freezer ok but fridge warm
If all else fails I would completely defrosted the unit.If there is any blockage this will open up all the tubes.Unplug it open the doors put pans of hot water in the freezer to speed up the process.
Make sure your fan is still working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refridgerater may be blocked.With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open 12 to 24 hrs this will free up any clogged tubes. Good luck.
Len West
Posted on Feb 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
my WSE6100Wa (westinghouse side by side) is not cooling on both sides
Posted on Jul 28, 2009
SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Posted on Jan 01, 2010
My homemaker small freezer is not freezing. It is model DD1-09. Adjusting the temperature does not make any difference it is keeping the contents cool but not freezing.
is there ice buildup inside the freezer if so you must thaw it our try using a hair dryer to make the thaw faster because ice freezover inside usually is the problem
Jan 13, 2018 | Refrigerators
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have two door bottom freezer in my LG refrigerator...Freezer is defrosting its' contents..I lowered the temperature but it still persists...any solutions?
My bottom freezer LG is intermittently shutting down and thawing everything in the freezer (cooling stops in fridge part, too). $3,500 for a refrigerator that works only 18 months.
Mar 18, 2013 | LG Refrigerators
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
Will freezer work in low ambient temperature (i.e. 26'F)? I have a GE refrigerator/freezer (c. 1983) in a cabin which gets winter temps around 25 degrees. I found the freezer contents had melted and then...
The compressors are rated for ambient temp. and most refrigerator compressors are rated for abour 50 degrees F
to answere your question yes the ambient temp is a problem.
And as for the Thawing, the refrigerator will go into defrost every 8 to 10 hrs and turn on the heater inside the freezer for about 30 min.
You can also cause damage to the seal system and the compressor because the oil will become slugish inside the compressor.
In other resarch I found that because of the ambient temp the freon gas (mostly the newer freon's) won't work corectly because they stay in liqued form.
Jan 11, 2010 | Refrigerators
Freezer circulating fan not working
Buy a pet cow, and all your problems will be solved!! :)
Jul 11, 2009 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Freezer not working
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
Westinghouse WRS3R3EW 33" 22.6 Cu. Ft. Side-by-Side Refrigerator w/ Plastic Freezer Basket, 4-Button... Logo
74 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
