Question about LG KM900 Arena Cell Phone
Automatically off after some times - LG KM900 Arena Cell Phone
  • 2,133 Answers
Battery weak. Replace it.
Posted on Dec 29, 2010
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
How do I change the time on my lgl34c
go to settings and select date and time.turn off automatic date and time and set the date and time to what you wish
Sep 27, 2014 | Cell Phones
How do i set the time on my kindle fire?
Tap the little gear icon in the upper-right, tap "More...", then tap "Date & Time".
If you want the Kindle to automatically set the correct date and time from the internet, make sure "Automatic" is set ON, tap "Select Time Zone" then set your time zone. Otherwise set "Automatic" to Off" then tap "Set Time", set the time, then tap "Set Date" and set the date.
May 02, 2014 | GPS
How to change time on a Kindle
The Kindle Fire is usually set to automatic date and time sync, this is how to override the automatic time set on the Kindle Fire.
Step 1: Pickup the Kindle, unlock if the device is locked
Step 2: Pull down the upper status Bar
Step 3: Select Date and Time
Step 4: Turn "Automatic" to Off
Step 5: You may now set the date or time by selecting the appropriate submenu item below "Automatic"
Apr 21, 2013 | Amazon Kindle Fire HD
How to set the time on dmr eh59
Automatic clock setting is done if you initially accept to use the guide plus system (should do). Only if for some reason it does not work, you can set the clock manually following these steps Clock Usually, the unit's setup function automatically adjusts the
clock to correct time. Under some reception conditions, however,
the unit cannot set the clock automatically.
In this case, follow the operation steps below to manually set the clock.
1 Press [3, 4] to select "Off" of "Automatic" and press
[OK].
2 Press [2, 1] to select the item you want to change.
The items change as follows:
Hour,Minute,Second,Day,Month.Year
3 Press [3, 4] to change the setting.
You can also use the numbered buttons for setting.
4 Press [OK] when you have finished the settings.
The clock starts.
If a TV station transmits a time setting signal, and when
"Automatic" in the Clock setting menu is set to "On", the automatic
time correction function checks the time and if necessary it is
adjusted several times every day.
Sep 25, 2012 | Panasonic DMR-EH59 250GB Multi Zone Region...
Setting time automaticlly
If you go into your settings you should see a section that says date/time settings. Go into that subsection and you should see an option for setting the time for manual and automatic. Select automatic and then it should set the time automatically.
Hope this helps!
Mar 25, 2012 | Samsung S8300 Ultra Touch platinium-red...
I have automatic aol schelued howcan i cancel this
Disable Automatic AOL The AOL software lets you turn off the the Automatic AOL feature any time you like.
Disable a scheduled Automatic AOL session You can disable all sessions or any particular session of Automatic AOL.
To disable a scheduled session, do the following:
1. Click the Mail menu, and then click Set Up Automatic AOL.
2. Click the Schedule Automatic AOL icon.
3. Uncheck the box next to the day which you want to cancel the scheduled session for, and then click the OK button.
4. Click the X button on the upper right of the Automatic AOL window to close it.
Disable the Automatic AOL scheduler When you turn off the Automatic AOL scheduler, Automatic AOL will no longer run at predefined times.
To disable the Automatic AOL scheduler, do the following:
3. Uncheck the Enable Scheduler box to clear it, and then click the OK button.
Jul 15, 2011 | Computers & Internet
Time on phone keeps changing and doesn't stay when I put the correct tome in...which I shouldn't to do right....its suppose to be automatic but its constantly giving me the wrong time...help please
Your secondary battery located inside your unit which is for correct time display maybe drained. I have the same problem with my phone. After I had it replaced by a technician, my phone clock display is now working nomal. Another option if you don't want your secondary battery replaced is setting your phone to automatically detect your network's time. Go to settings, look for time and date settings and locate the automatically update time or something like that. Everytime you turn on your phone, it should automatically detect and display a correct time.
Dec 19, 2010 | HTC EVO 4G Smartphone
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
My Aquaracer Automatic doesn't keep exact time
you bought a automatic watch, they are a quality time piece, not an acurate time piece. if you want acuacy buy a cheap quartz watch.
Apr 07, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
LG KM900 Arena  Cell Phone Logo
15 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
