Question about Microwave Ovens
Looking for the manual for a panasonic microwave NNV652W? or nearest as I can get ...Thanks
I have been given a Panasonic combi inverter microwave/oven. There are no user instructions can you help me to find a manual?
here is the link to the instruction manual of your device from panasonic:--
click the link directly:--
http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/model.NN-H275BF
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 06, 2009 | Panasonic Microwave Ovens
Panasonic Model #NN7524A Microwave bulb replacement help
microwave---NN-S335 , 800W Plate exploded , Where can I get another ? From C Carver Feb. 23 , 2009 Thanks
Feb 25, 2009 | Panasonic Microwave Ovens
How to get hold of a manual to re-programme my ne1856?
While that one is not listed, you can find similar ones (probably one close enough to yours to work for you) here.
Otherwise, visit http://panasonic.net, select your country, then look for customer support.
Feb 05, 2009 | Panasonic NN-2505A Microwave Oven
Operates for 3 seconds on microwave then stops
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It could possibly be as simple as a loose connection in that area. The repair shop your friend used may not have been Panasonic-authorized.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 15, 2008 | Panasonic NN-C980 Convection/Microwave...
I live in Austin, Tx; what is the nearest repair service qualified to work on the Panasonic NN-C994S Convection-Microwave oven?
You can find your nearest Panasonic-authorized servicer here.
Sep 11, 2008 | Panasonic Microwave Ovens
New Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it's still not working, you'll need to contact your nearest Panasonic-authorized servicer.
Aug 24, 2008 | Panasonic NN-P295SF Microwave Oven
Panasonic NN-H664
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
You can order Panasonic parts here.
Or you can contact your nearest Panasonic-authorized servicer.
Aug 08, 2008 | Panasonic NN-H664 Microwave Oven
Operators manual for NN-ST656W Panasonic
Your search is complicated by the fact that this is an Australian model.
Your manual and other documents related to this model can be downloaded from this page.
Aug 02, 2008 | Panasonic NN-T888S Convection/Microwave...
MESSAGE DISPLAY H98
The H98 fault on a Panasonic can be a bad magnetron, inverter or control panel.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 27, 2008 | Microwave Ovens
Microwave Ovens Logo
146 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
