Question about Air Purifiers
I have a Evcon EB15B heat pump system, recently it has been running constantly and the heat just is warm, trying to figure out if this is in the heating element or the thermostat
  • Air Purifiers Master
  • 43,501 Answers
The problem is probably neither..the system has developed a leak in the refrigerant system and is low on freon....
Find a liscenced tech to check the system for you and correctly fix, vacuum and charge the system for you...
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Jan 04, 2011
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Squealing sound from our mini-split!
If it were a car I'd say something to do with the belt. Maybe check that out.
Jan 01, 2014 | Klimaire 24,000 Btu 18 SEER DC Inverter...
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
Everything works but the fan will not turn. I recently performed a thorough cleaning and installed a new ozone filter, but the fan will not turn. I tried turning the fan manually and the unit would run...
The fan needs oiling (except for the Fresh Air, which has sealed bearings and no removable front grid). I need to know which model you have to help you reach the fan shaft. However, if you're handy, you can figure it out. Remove the front grid (if there is one on your model) and pull off the fan blades. Use a light household oil (sewing machine, hair clipper, 3-in-1) to drip down the shaft as you turn it manually. This should take care of the problem.
If not, and if you need more extensive repairs or rebuilding, call Vollara (new name for EcoQuest) customer service at 1-800-989-2299 and use 16618 as your dealer referral number.
Jan 30, 2011 | Ecoquest Air Purifiers
F300E powers up in purge mode, but shuts off when heating
In the heat mode your furnace fan operates in a lower speed. when your zone panel purges it powers the G terminal in your furnace, which is high speed. You may have an airflow problem if your EAC is powered directly to an outlet, you may have a bad air pressure switch, or if the eac is wired to the furnace control board, it is mis-wired..more info needed.
Dec 12, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Evcon Model EB15B Elements glow red for 3 minutes then cycles off. Fan stays off during the cycles. Manual fan switch will turn on the fan. Assistance requested, cls
the fan has to be on while the strips are on. knowing that the fan comes on when you switch it to on at the thermostat but not when your just calling for heat indicates that you have somting wrong with the heating relay or the fan isnt wired properly to the heating relay (posssibly a new motor during the summer) or just a bad relay. when the first stage heat comes on it should also energize the motor the first to come on is also the last to shut off which will make sure the fan runs during the whole heating cycle. until you remedy this you can run the heat just keep the fan switch set to on so its running, this will not hurt anything
Nov 24, 2009 | Air Purifiers
I just washed the electrostatic grid and didnt have it thougholy dryed before inserting it back into the unit. Now I cant get the power light to turn on
As long as you have the cells in the correct direction, the air flow direction you should be O.K. If you have a way of turning on a constant fan that will help dry them. I would shut the power button off to the electric air cleaner and run a constant fan for 24 hours. After that, turn the power on and the constant fan off. Turn up the heat and see if it works.
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Apr 13, 2009 | Air Purifiers
Air Purifiers Logo
66 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
