Question about Video Game Consoles & Games
I have a PS3 that I'm having an optical cable problem with. I have a KEF home theatre system, which i have connected to the PS3 via an optical cable. This works fine on the menu system and when watching a blu-ray film, but I have no sound when I load a game. I also have an Xbox 360 with the exact same set up and it works fine. there is light coming out the optical cable from both ends when plugged to the PS3. Please help me out. :)
    Champion:
  • 207 Answers
Hey,
ok so shut the system off via the back power switch then switch it back on and wait for the red light to appear.
Then push AND HOLD the power button n the front down until it beeps (dont stop pushing until it beeps at you) it will then reset itself and you will be on your way!
Posted on Jul 07, 2008
I have an RCA home theatre...model rt2910. I have hooked my PS3 via HDMI to the TV for the video and used an optical cable for the audio. I set the PS3 to send video via HDMI and audio via optical cable....
You should have the HDMI plugged into the Home theater unit. The theater unit then is attached to the TV using the HDMI out.
The home theater unit passes the HDMI through to the TV while playing the audio for you.
You will likely need to select the correct source on your RT2910.
Here is a link to the manual.
http://www.1800customersupport.com/productdocuments/RT2910_RCA.pdf
See the section entitled "Connecting to HDMI Components" for an illustration of what I have described above.
Feb 28, 2011 | RCA RT2910 Theater System
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Have pitcher no sound with my home theatre system
use an optical cable from your ps3 for sound to your amp, or use the red/white rca's on the cable the ps3 came with to go directly to your amp.
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
Digital optical connection is creating any sound
Check to ensure the Home Theater is outputting the digital audio via the optical cable.
Nov 21, 2007 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Please help with getting 5.1 sound from my TV!
You must run a Digital Optical cable from your PS3 to your reciever. Then press your function button on your recievers remote until you see SAT/CABLE on your recievers display. Next go to your PS3 settings and go to Sound settings, then Audio Output settings, and select Digital out (OPTICAL) then your done. This is the only way to get true digital sound from your PS3 to your reciever.
Oct 01, 2007 | Sony DAV-HDX500 System
Set up help!!
Firstly connect your home theatre outpu HDMI to HDMI input1 on the TV. Then connect the PS£ HDMI to the other HDMI input on the TV. Now connected the optical cable from the PS3 to the optical input of the home cinema system. Your should now have surround sound from the PS3 and DVD.
Sep 11, 2007 | Samsung HTP-1200 System
Video Game Consoles & Games Logo
48 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
