I can't turn it on....it works when plugged into the usb
  • 204 Answers
This problem is mostly due battery failure.
Posted on Dec 29, 2010
How to get my keyboard back working on my desk top
1: if the keyboard has a round plug going into the computer, it is a PS/2 plug. Turn off your computer, unplug the keyboard, then plug it back in, making sure it is plugged into the correct place for the keyboard (and not the mouse). Then turn the computer back on.
2: If the keyboard has a USB plug, it is not necessary to turn off the computer first, just unplug the USB cable for a few seconds then plug the cable back into the computer. If it still doesn't work, try plugging the USB plug into another USB port on the same computer.
3: If neither option works, you may have a defective keyboard.
Sep 05, 2017 | Top Computers & Internet
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Webcam does not turn on
that is a very good hypothisis that may be why cam isnt working, try the front usb plugs
May 08, 2010 | Toshiba PX1342E1CAM Webcam
Usb ports quit working on my hp netbook 1151nr mini
Recheck bios and verify usb ports are turned on.not sure how?just let me know ican walk you through this.RICHARDM69
Aug 24, 2009 | HP Mini Notebook
Usb device not recognized when i plug in my zune
Turn off the CPU pull off the power cable, unplug all usb cables, Let it sit for about 15 mins. Plug it back in start the CPU plug in your device. This will reset the motherboard, as just turning off CPU the motherboard still has power. If still does not work, you can either re-do windows, or get a USB/PCI Port Card, thatll have like 5 usb ports on it. And try that.
Aug 03, 2009 | Microsoft Zune JS8-00001 Digital Media...
PS3 Controller will only work when plugged into the USB
i had same problem turn off your system with controller plugged in to usb unplug controller remove the power cable for a couple of mins reconnect and use controller PS button to turn system on and it should be back to normal. it worked for me
May 31, 2009 | Sony Playstation 3 (PS3) Console
Pci card doesint work
What you want is a USB hub.  That will allow you to connect more than two USB devices to your computer.  There are two types, USB 2.0 and USB 1.1.  USB 1.1 will work for most slow speed devices, USB 2.0 is better for cameras and hard disks that have the support.  You should confirm which version of USB your computer has, but you should be OK getting a USB 4-port hub, plugging that into your computer, then plugging your keyboard and mouse into the hub and using the other port for the new peripheral that you wish to install.  Old PCI cards are problematic because you need the correct drivers.  You also need to make sure you plug them into the proper PCI port.  It sounds like the device you got from e-bay might be bad, so you shouldn't continue to use it.  If you post the make / model of your computer we might be able to suggest a new PCI card that will work if you still want to add more ports to your computer.
Apr 21, 2009 | VIA Vectro VT6212 (A62124) Serial Adapter
USB/connection
I have to turn the power on to my camera when I plug my older Powershot in to the USB connection. The camera does not turn on, but the computer then recognizes the camera.
Dec 31, 2007 | Canon PowerShot A540 Digital Camera
12 people viewed this question
 Grubhead
Grubhead
