Question about Sub-Zero Refrigerators
06 error code ice build up on back wall - Sub-Zero Refrigerators
  • 3 Answers
Defrost heater or defrost timmer not working.
Posted on Jul 07, 2008
Kenmore model 795.71022.010 water builds up in the bottom of the freezer every two weeks I have to defrost the unit and remove the ice build up if I dont the door wont close
The fan unit behind the wall inside the freezer may have frozen over.
Even though you see no ice inside the shell of the freezer, it can still have blocks of ice behind the back wall.
So remove the 3-4 screws holding the back wall, remove it and check on the ice there.
Make sure it is completely defrosted or ice melted before reconnecting. Leave the wall off while you connect it to make sure the small fan is kicking in.
IF the fan does not kick in. you can get a replacement for $15-$20 at any fridge parts supply house. It is easy to disconnect and reconnect.
Jun 04, 2016 | Kenmore Refrigerators
Kenmoore elite 106.57706701 fridge and freezer
is there ice build up on back wall of freezer? if so evap coils are iced up and fan cannot flow air across them due to ice build up.
remove back wall and hair dryer them free if the ice start up fridge and see if it cools if it does bad defrost cycle, if not compressor or condenser fan bad
Aug 27, 2014 | Refrigerators
We have an error code on the water dispenser screen - Er IF What is the fix for this problem? This is an LG French door model LFX25950SB.
You have a ice fan motor problem. This fan motor is what feeds cold air to the icemaker. Try unplugging the refrigerator for a few minutes to reset the computer. Plug it back in and see if the error code stays off. If it returns, you will need to remove the ice fan motor from the freezer and see if ice has built up and blocked the air flow. The ice fan motor is located behind the back wall inside the freezer. You will have to remove the drawers and slide supports to remove the back wall. There are 2 fans behind the wall. The one on the left is the ice fan motor. Good luck.
Jun 22, 2011 | LG French Door Refrigerator with External...
Tempreture on fridge too high ice build up in fridge mahes noise like a tractor
Your automatic defrost cycle may not be working. Feel the walls inside and if they are hard solid you have ice build up and the fan is hitting the walls or ice making the noise. Unplug your fridge for 2 days and let the ice in the walls melt. Put towels on floor to catch water. Plug it back in and it should run fine for a couple of weeks until the ice builds up again. You have a bad timer and it isn't letting the defrost cycle come on. Defrost cycle are heating elements that melt the ice build up and runs about 10 mins once a day or so. This will give you time to check if an afforable repair can be done or a replacement fridge.
Jul 11, 2010 | Samsung Refrigerators
Thick ice is building up on the inside back wall, i'm
not defrosting it totally, unplug unit and use a blowdryer to defrost the return air ducts, they are located behind the panel on the rear wall of the freezer
Oct 28, 2009 | AEG S72348KA ST STEEL Refrigerator
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
My feezer builds up ice at the back on the bottom
That is one of the symptoms of a failed blower fan. Typically on Frigidaire it's behind the metal shield with the thermostat knob at the back of the freezer. Go to an online parts place and look at the diagrams. To see it the fan is failed. Unplug from the wall, remove the shield, if you have an icemaker remove the two screws holding it on the wall and it's connector, then plug in the wall and either check for voltage or watch to see the fan spin.
Sep 26, 2009 | Frigidaire FRT21H8 Top Freezer...
Hi, On my LG LRFD25850ST I am getting an error
er-ff is freezer fan error not running,check for ice build up around fan,a know issue.if ice build up a new main board will be needed.or just a bad fan..
Jun 20, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Frig not cold
check to see if the back wall of the freezer has ice build up if so that will be an automatic defrost problem
May 02, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Sub-Zero service manual
Here is a link to the error codes. If there is a fault condition these should be flashing on the display:
http://fixitnow.com/wp/2006/06/29/error-codes-for-the-sub-zero-600-series-refrigerators/
One this to try is a hard reset: unplug and wait for a few minutes and re-plug back in. Sometime this resets the service condition and will then display the error codes.
Ice is displayed when the ice maker is turned on. Press the ice on/off and it should turn off.
Feb 19, 2009 | Sub-Zero 642
Refrigerators Logo
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
