Question about Makita Garden
My makita keeps sticking and not firing out the nails getting frustrated with it
  • 784 Answers
Check the air pressure from the compressor -- I am sure that you need 80 -100lbs of pressure in order to shoot and complete a cycle. also drop a few drops of oil ( tool oil ) into the air intake hole and also put some oil along the firing pin slide,, also check to see if the load spring is strong and not broken or disconnected.
c...
Posted on Dec 29, 2010
My makita nail gun was firing 3 nails at once. Now its not firing any and it appears to have come apart at the casing. Help!!!!
yep they do that
extreme care needed to take the gun apart
especially if the rail of nails seperate in the tool
or drum type dispenser if fitted
choose your model see if the user manual helps in repairing
http://powertool.manualsonline.com/manuals/mfg/makita/makita_nail_gun_product_list.html
May 10, 2016 | Makita Air Tools & Compressors
My makita an451 roof nailer keeps shooting 2 nails I've tried 2 different brands of nails
Nailers that use strips of nails (one nail directly behind the other) will sometimes drive two nails at once and is caused by damage to the driver. The nails are so close together that the driver will hit the first and part of the second nail head. Coil nailers, as your an451, use nails seperated by welded wire making it very difficult the the driver to hit the second nail. Usually when a coil nailer shoots two nails, it is acutally the trigger valve that acutates twice (two very rapid fires). Two very rapid fires is caused by faulty trigger valve. I have seen a roofing coil nailer fire one nail and a second nail drops out of the gun. Caused by weak / malfunction of nail feeder or wire used to weld nails together is too thick.
Sep 17, 2011 | Makita Roofing Coil Nailer AN451
Makita gn900 nail gun wont fire on half full gas cell
Hi... mine had the same problem when I bought it cheap second-hand. I made a spacer out of a washer that slips over the gas stem adapter and so far 100% fire rate. It holds the adapter closer to the cartridge nozzle and opens the valve that releases the gas when the trigger is pulled. Too easy! Good luck.
Sep 08, 2011 | Makita Tools & Hardware - Others
Nails don't feed
could be a couple problems. First are you using the right collation nails and do you have the tray set for the nail length. Second, remove all the nails and open up the feed door and check to see if the spring is still on the feed pawl. Then what I would do is get a block of wood and dry fire the tool lookng for the feed pistion to snap back and forth freely, if it moves slowly could be an o ring that is dry or something got into the air passage causing this. Let me know if you need more assistance.
Feb 12, 2011 | Makita AN611 Siding Coil Nailer
Nails jam by sending 2 nails at once
You can find a parts list at the following address:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/AN451
Rebuild kit # 192393-0 (search ebay for lowest price) will usually fix your problem. But for immediate/ temp fix try adjusting the depth thumb screw all the way down or all the way up and lower the pressure a little. Sometimes it helps to put the firing pin in a different position. I believe that fine scratches on the oring contact surfaces in the headvalve actually cause this problem. Before you install the rebuild kit, examine headvalve parts with magnifying lens and sand fine scratches with 300 - 400 grit sandpaper. Lube orings in the headvalve with silicone paste (Danco brand sold at Lowes in the plumbing department) it will help get a good seal. For best results replace the headvalve springs. I do not believe that they come in the kit. Good Luck with the repair.
May 10, 2009 | Makita Roofing Coil Nailer AN451
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Dont know what nails to use on my makita brad nailer
is that a model AF505? if it is, your problem may be the gauge. make sure you use 18 gauge nails, he 16 gauge are too big and will jam in the gun.
Feb 26, 2009 | Makita Brad Nailer Finish Nailer...
Makita AN 901 framing nailer blows nose end apart
not too familiar with makita brand nailers but jams are usually caused by cheap nails but I see you have tried senco brand which is a good brand sounds like a mfg defect try using hitachi brand nailers they are good
Dec 26, 2008 | Makita AN901 Coil Nailers
Garden Logo
49 people viewed this question
Top Makita Garden Experts
Jim Parker
Jim Parker
JOHN LAPIER
Are you a Makita Garden Expert? Answer questions, earn points and help others
