Question about Microsoft Xbox 360 Console
One flashing light on xbox 360 and e74 on the tv bought the console used from game stop and this happened
Just Do towel trick
all you have to do is be sure that u that you have the error next take the av cord out the 360 and keep the power in then keep it on then get like 3 towels i just use a towel, a rob, and a bed sheet LOL once u complely coverd the the xbox, keep it on for about a half hour 45 mins. or untill it the xbox gets very hot. once you comformed that its hot, take off the towels or whatever and let the 360 cool down for about 20 mins. or till cool. once thats done plug everything back up and pray to work and its not permentat but enjoy and if happens again do it over
Note: The Sysysten will need to overheat just be in mind of a fire or suthing i dought its going to happen
PS: In this process u will not get the RROD iight
Posted on Dec 29, 2010
E74 error and flashing light on xbox 360
Your console has a general hardware failure, if your console is less than 3 years old, and has not been tampered with in any way, ie: the console has not been opened, microsoft will repair this FREE of charge,
visit www.xbox.com/support to book a repair.
Mar 09, 2010 | Microsoft Xbox 360 Console
3 flashing red lights error message E74 consoles frozen
3 red lights on the Xbox 360 is the most common error and it means "General Hardware failure. To fix this you need to stop the amount of heat that the GPU and the CPU is taking.
To do this you can use the recommended guide that has been on the market for 3 years or you can send it in.
Feb 03, 2010 | Microsoft Xbox 360 Console
Single red flashing light and system error E74 showing on the TV
The E74 error is caused by the scaler chip at the back of the console taking too much heat. To fix it you need to stop the heat build up.
You can do this yourself using a good guide that will show you how to fix it with household items or you can send it in and they will fix it for you.
Jan 21, 2010 | Microsoft Xbox 360 Console
I have code error 74
Code E74 1 red light flashing and error message on screen right? It is the scaler chip, it happens because the scaler chip starts overheating. If you stop the heat build up on the chips then you should be fine.
You can send your Xbox 360 back in for repair or fix it yourself with a good Xbox 360 Repair guide
Oct 28, 2009 | Microsoft Xbox 360 Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
The flashing red light comes on with message E74
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
hope i'll help you..:-)
May 17, 2009 | Microsoft Halo 3 for Xbox 360
Halo Special edition xbox console: Error E74 after update
the odds are very good... The error is caused when there's a problem with video, either because the A/V cable used is broken, or what's even worse, when Ana, the Xbox 360 hardware scaler chip is damaged. Also try this take the AV cable, plug it out and plug it in, if it still doesn't work unplug it, wipe the metal part with a soft cloth then plug it in. That might help.But i bet you will end up sending it off again.
Feb 19, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 e74
You have to have it repaired.
May 19, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
60 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
