Question about Cisco WAP200 802.11b/g Wireless Access Point
I have a new wireless-g access point with power over ethernet and range bootster...model no.:WAP200 when i connect it to power and ethernet to configure it wireless led and ethernet are turned on and when i enter password the power is disconnected from wireless access point and when it connected again the below happen when i connect power the wireless led is turned off and ethernet is on and i can't access wireless access point and my labtop don't discovery access point i want to know what happen ...there is a hardware error in wireless module when power diconnected or software problem and can be solved please respond
5 Suggested Answers
SOURCE: My PC is not detecting the wireless Access Point
make sure guest mode is set on the ssid so that it will broad cast.
Posted on Dec 05, 2007
  • 366 Answers
SOURCE: Steps for testing en repairing tthe Access point
Try my tips and start connecting to access point using LAN cable
Posted on Jan 07, 2009
SOURCE: I am using Cisco WAP
For that press RESET button it is in the back side of access point hold it for 10 seconds then all settings defaults then reconfigure it again. You can configure it with below method. You can also configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. or or or If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Apr 24, 2011
  • 561 Answers
SOURCE: I could not access the web based
once u put the wireless access apoint in your network check ur dhcp server there u will find in ARP table the ip of your access point. then u can access it through that ip.
Posted on Aug 19, 2011
CISCO WAP200 constantly loses connection
Your printer is probably going into "sleep" mode after "X" minutes, which may be causing the problem. Use the led interface on the printer to keep it out of sleep mode and that may help.
Jun 24, 2017 | Cisco WAP200 802.11b/g Wireless Access...
I could not access the web based configuration/setup page for my Linksys wap200
Aug 19, 2011 | Linksys WAP200 (LS-WAP200) 802.11b/g...
Hallo, i recently installed and configured a WAp200E-EU-UK access point. i changed the default ip address to and changed the SSID and key, when i logged out of the web interface, i could not...
As you have changed the default IP Address of the router, you can access the router by using the newly assigned IP ( and new username and password (if you have made any changes to the defaults).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
Jun 20, 2011 | Linksys (WAP200) (WAP200-UK) 802.11b/g...
I need to locate the default IP to my Linksys WAP200. The default has been changed and the owner cant remember what it was changed to. The owner cant afford to lose the configuration settings.
Plug a laptop into just the linksys. Make sure nothing else is connected. Then on the laptop go to start -> run and type cmd. In the black box type ipconfig. This should show you the ip settings on the laptop. There should be one with a default gateway filled in. This will be the lynksys's IP address.
May 31, 2011 | Linksys WAP200 (LS-WAP200) 802.11b/g...
How do i set bridge mode?
Depends if you need a wireless or wired bridge?
Here is some info for you.
Infrastructure Mode
With a wireless Access Point, you can operate the wireless LAN in the infrastructure mode. This
mode provides wireless connectivity to multiple wireless network devices within a fixed range or
area of coverage, interacting with wireless nodes via an antenna.
In the infrastructure mode, the wireless access point converts airwave data into wired Ethernet
data, acting as a bridge between the wired LAN and wireless clients. Connecting multiple Access
Points via a wired Ethernet backbone can further extend the wireless network coverage. As a
mobile computing device moves out of the range of one access point, it moves into the range of
another. As a result, wireless clients can freely roam from one Access Point domain to another and
still maintain seamless network connection.
Wireless Bridging Overview
Using Wireless Router as a Wireless Access Point
May 03, 2011 | NetGear RangeMax WPN824 Router
AP is broadcasting SSID but can't get ip address from DHCP server. POE light is on, but ethernet link light isn't on @ AP or switch. May have been connected to a faulty cable. Any ideas? Is the ethernet...
It sounds like either a faulty cable, a loose cable (i.e. not plugged in securely), or failed autonegotiation, or the port on the switch or WAP has somehow become disabled. Since that model of WAP has auto-crossover capability, using a crossover or regular network cable would be irrelevant. What kind of switch are you plugging it into? Cisco switches, for example, can have MAC restrictions or othe security features. I would replace the cable with a known good one first, and examine the log on the WAP as well as the switch (if it's a manageable switch). Let me know how you make out and we can do some further testing if you'd like.
Feb 24, 2011 | Cisco WAP200 802.11b/g Wireless Access...
Default IP 192.168.1 doesn't work , how can I setup and secure password on my wireless
because default IP is not
Leave rate if I helped you, thanks!!
May 09, 2010 | Linksys WAP200 (LS-WAP200) 802.11b/g...
Need basic step-by-step instructions on how to install my router.
To Configure the Router with Internet Access
Connect to one of the wireless router/access point's LAN Ethernet ports, turn off its DHCP server, and give the wireless router a static IP on your LAN:
  1. Connect a PC directly to a LAN port on the wireless router with an Ethernet cable.
  2. Power on the wireless router/access point.
  3. Reboot the PC.
  4. Log in to the wireless router though a browser. (Usually, with User Name = admin and Password = password, unless you changed them from the defaults).
  5. Go to the LAN IP menu and disable the wireless access point’s DHCP server by unchecking Use router as DHCP server.
  6. Select LAN IP, and change the IP to
  7. Click Apply to save the settings. You will lose the connection to the wireless router/access point , since its IP changed.
  8. Log in to the wireless router/access point with the URL:
  9. Connect one of the wireless router's Local (LAN) ports to your existing network.
This completes the wireless router/access point configuration.
  • You can now log in to the wireless router/access point at its new address of and configure wireless features such as WEP and Access Control List
  • UPnP, DMZ, Port Forwarding, and Port Triggering are not used on the wireless router/access point, and it doesn't matter how they are configured.
  1. Configure the LAN IP address to be within the same subnet as your PCs.
    • Take care not to use an IP address already being used.
    • Limit the number of addresses in the DHCP range and assign an IP address outside of the range to the router you want to use as the Access Point.
  2. Disable DHCP on the wireless router/access point.
  3. Connect one of the LAN ports on the wireless router/access point to a LAN port on the Router.
  4. Configure the SSID and any security settings on the wireless PCs to match the wireless router/access point's SSID and security settings.
a. SSIDs must be the same on all wireless devices. (These are case-sensitive: netGEAR is not the same as NETGEAR.)
b. Tip: Make sure the wireless PCs can connect before configuring WEP, WPA-PSK, or other wireless encryption.
Jan 02, 2010 | NetGear WGT624 Wireless Router
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Cisco WAP200 802.11b/g Wireless Access Point Logo
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
