Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
Gents; We have SSR 100HP Ingersoll rand (watercooled) air compressor and it is not giving high pressure (low pressure =0.5 bar only). We changed the Unload/Load valve and checked again but we have same problem. We checked if the pressure line of the solenoid valve and found that there is no air supply to this valve. please advice where could be the problem? Thanks in advance. Mohammed Alhajri
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
SOURCE: I have an ingersoll rand ssr-ep60 with intellisys
There have a hidden button to turn on to do setting
Posted on Mar 31, 2010
  • 40 Answers
SOURCE: i need an exploded view of a ingersoll rand ssr
air end exploded view?
Posted on Aug 09, 2010
  • 214 Answers
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Posted on Mar 28, 2011
  • 54 Answers
SOURCE: What does alarm start fault
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Posted on Mar 29, 2011
Ingersolll Rand website support section should be able to provide a manual.
Failing that contact customer services.
Aug 03, 2016 | Ingersoll Rand Air Tools & Compressors
My ssrxpe60 ingersoll rand compressor is giving a high air pressure alarm and shuts down
I may be missing something here but typically a SSR is a rotary screw machine.XPE 60 is the model. It probably has a controller of some type for this person to know its shutting down on high air pressure alarm. So as the previous person kindly said don't give advise on something you know nothing about before you get some one hurt or killed!!!!
To answer the question. You may have a pressure transducer bad but most likely you have a minimum pressure check valve stuck in the closed position. When the compressor starts air pressure in the separator tank builds. At approximately 65 Psi the MPCV opens and allows air to the after cooler and out into the system. If the MPCV doesn't open the air pressure in the separator tank becomes to high. You then get the high pressure alarm and the unit shuts down.
Make sure the air pressure is zero, electrical disconnected and discharge line isolated from system. Once done you should be able to unscrew the aluminum cap on the check valve. Be extra careful due to spring tension. It should loosen as the cap is removed. If the parts inside are very corroded or you are unable to remove the cap you may have to replace the complete valve. If able to disassemble clean and purchase a rebuild kit for your MPCV if available.
Feb 21, 2015 | Ingersoll Rand Air Tools & Compressors
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
I'm working on a Ingersoll rand 100HP stationary compressor with an intellisys 39875158 controller.
Make sure the model of your compressor is design for 160psi if not the main motor trip off and safe valve pop. Goto Main Menu, Operator setpoint+select, Offline/Online+select, arrow up and down to change value.
Jul 04, 2012 | Ingersoll Rand Stationary Air Cooled...
We have an Ingersoll Rand- 100hp air compressor. We only run this periodically- when we have a power curtailment and trying to reduce power consumption or if our primary air compressor faults out. When...
replace the hat switch. hat = High Air temp. This switch is located on the end of the air end and usually has 1/2" flex conduit on it. Remove the conduit. It goes to a box located on the frame near and under the airend. Remove the cover from the box tug on the wires at the hat switch to see which two wires need to be disconnected.disconnect wires unscrew hat switch. Put a new oring on the new hat switch and install new hat switch. Hat switch is the only switch that will give high temp and lose control power. Let set a while and can reset unless probe is broken off.
May 31, 2011 | Ingersoll Rand Stationary Air Cooled...
Our company has ingersoll rand air compressor model SSR MM 150 is giving high temperature of air ultimately facing moisture problem at downstream of dryers.Need your assistance.Kindly send the manual if...
make sure the cooler is clean..change the oil filter if hasn't been changed in a while..could be bad thermo valve..oil level?How many hours on machine?
Nov 06, 2010 | Air Tools & Compressors
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Cuts off with no reason
hi mate when the reach there working pressure e.g.150psi/10bar they shut off and then when the pressure drops to a pressure of e.g. 100 psi 7 bar they automatically start back up and pump back upto they working temperature or if it dont start at all it could either be a faulty pressure switch or a fualty star delta starter if its 3 phase 415 volts if its 240volt there are only a pressure switch which will be faulty get a sparky in to sort it out there buggers to mess with 415volts 240 volts easy
Jun 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
149 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
