Question about Panasonic KX-TG2740 Cordless Phone
No link to base
The base unit was unplugged and the battery ran down on the handset. Now the handset is charged but we still get the error message that there is no link to base. can you help thanks?
  • Anonymous Mar 17, 2014
    I get a digital readout on handset saying move phone closer to base... but phone is next to base. Is it a battery?
  • Anonymous Mar 22, 2014
    I took the battery out, unplugged and waited 3 min., am still getting this error message
  • 405 Answers
Good Day,
See this link, this is pg 105 of the manual on how to re-register the handset to the base.
http://www.fixya.com/support/p123254-panasonic_kx_tg2740_cordless_phone/manual-7363/page-105
Hope this helps
Posted on Jul 07, 2008
  • Patrick McGee
    Patrick McGee Jul 07, 2008
    Also see pg 104,
    If you have not canceled the handset registration at the previous base unit (p. 104), the handset number still remains on that base unit memory. To erase the handset number from the previous base unit, see the base unit Operating Instructions. For KX-TG2740S base unit: (1) press (FUNCTION), (2) press (MUTE), (3) enter 335#, and (4) enter that handset number ((1) to (8))
Battery charged displaye no link to base
Many models of cordless phones that have multiple handsets require the handset to be cradled in the base unit for identification and link. As long as the handset maintains a charge, the identification remains valid. If you remove the battery or drain the handset to a point where the handset ID is lost, then you may have to re-cradle the handset in the base unit to reestablish link.
Mar 19, 2015 | Lands Phones
Hi I have a Cordless Uniden Dect 6.0 and also another one that sitts on a bitter base. My problem is this: the cordless with the smaller base shows the message 'Searching' and wont do anything,...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 11, 2011 | Uniden D1680 Cordless Phone
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Aug 29, 2009 | Panasonic KX-TG9331T Cordless Phone
ATT 5840 Base reset code/procedure
document.write(parent.prscreen) Try this to get it working. Relocate the handset(s) closer to the main base.
Check for any lights on the base including charge, intercom, and channel lights (if applicable to the model).
Re-cradle the handset on the base for 15 seconds. Lift the handset and press PHONE.
Unplug the AC adapter from the main base unit and take out the battery from the handset. Leave it unplugged for 15 seconds. Plug the handset battery in and re-cradle the handset. Plug back the AC adapter in and wait for 15 seconds.
Try to de-register the handsets by following the steps below:
1. Using the soft keys on the base located below the base screen, press MENU
2. Press the down arrow once until BASE SETTINGS is highlighted.
3. Press the OK soft key.
4. On the base, press MUTE 3 times and FLASH twice. This will
deregister the unit.
Below are steps on how to re-register the handsets:
1. Make sure to charge the handset battery pack at least 12 hours.
2. Using the soft keys on the base located below the base screen, press MENU.
3. Use the up or down arrow keys to select DISPLAY BASE ID.
4. Press OK. The base screen will display the 15-digit Base ID
code for about 30 seconds, then the unit returns to the idle
screen. Write down the Base ID code on a piece of paper.
5. At the cordless handset, use the soft key to select NEW.
6. Enter the 15-digit Base ID code using the number keypad.
7. Use the soft key to select OK. The screen displays PLEASE
WAIT!.
8. After about 45 seconds, the screen displays FOUND BASE. If the handset displays BASE BUSY TRY LATER, the base is in
use.
Other products that use the 5.8GHz band can interfere with the use of this phone. These products or equipments include: radio towers, page towers, cellular Phones, other 5.8GHz cordless phones, intercoms, or monitors. If any of these are in the area, they may interfere with the performance of the phone. Try relocating the phone.
Video displays, Televisions or Personal Computers can cause
interference on the phone if it is plugged in electrically with one of this equipment (typically on a power strip or extension cord). Please relocate the phone to an AC outlet without any other major appliance plugged in.
You can also relocate the base to another room.
Relocate the phone out of the kitchen area. Appliances may cause interference.
If the charge light does not remain on, clean the handset and base charging contacts using a pencil eraser. If it comes on after cleaning the contacts, you may need to charge the unit for 10 hours.
Make sure that the AC power cord is securely plugged into the base. If unsuccessful, plug the unit into a different known working outlet or turn on the switch on the power strip.
Dec 19, 2007 | AT&T 5840 5.8GHz...
No Link to Base
to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Panasonic KX-TG2740 Cordless Phone Logo
611 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
