TMESSAGE.TSF: GetLastError: 64 (40) - Computers & Internet
    Guru:
  • 443 Answers
When do you get this message? Is it a home PC or office network?
Cause:
This problem occurs when the TEMP or the TMP environment variable has a space character in the folder name. For example, the following TEMP environment value may cause this problem: D:\Documents and Settings\UserName\Local Settings\Temp
Resolution:
To work around this problem, change the value for the TEMP or the TMP environment variable for the system account and for the user account that will be used to install SQL Server 2000 64-bit. If you want to restore the values for these variables after the installation, make a note of the values before you change them. To change the environment variable values, follow these steps:
  1. Create a folder at the root of the local drive and name it TEMP.
  2. Click Start, right-click My Computer, and then click Properties.
  3. In the System Properties dialog box, click the Advanced tab.
  4. Click Environment Variables.
  5. Repeat the following steps for both the TEMP and the TMP User variables:
    1. In the User variables list, select the TEMP variable, and then click Edit.
    2. In the Variable value box, type %drive%\TEMP, and then click OK.
      Note %drive% is the local drive where you created the folder in step 1.
    3. Repeat steps a and b for the TMP variable, if it exists.
  6. Repeat the following steps for both the TEMP and the TMP System variables:
    1. In the System variables list, select the TEMP variable, and then click Edit.
  7. Click OK two times to close the System Properties dialog box.
  8. Click Start, click Run, type cmd in the Open box, and then click OK.
  9. At the command prompt, type the following command to verify that the TEMP and the TMP environment values are equal to%drive%\TEMP:
    set t
  10. At the command prompt, in the root of your SQL Server 2000 installation folder, type the following command: setup.exe /l*v C:\TEMP\setupfail.txt
Note If you want to restore the values for the TEMP and the TMP environment variables after the installation, follow step 2 through step 7 to restore the original values.
Hope this helps you.
Posted on Dec 29, 2010
How to reboot printer Xerox DocuPrint C4350 error code : printer 124-315
This is the error I get from GetLastError() after calling GetPrinter() to get the size needed to declare the PRINTER_INFO_2 structure:
An unexpected error occurred when executing the test.
Error Code = 124.
Error Message = The system call level is not correct.
for more help visit CBR Tech Solutions
Nov 15, 2015 | Xerox Office Equipment & Supplies
Error message when trying to install driver for windows 7 32 bite on macbook for usb to ethernet.
Windows driver is for windows not for apple. So none of windows drivers will work on apple and viceversa.
Feb 03, 2015 | Computers & Internet
.how to open tsf file
Hello vv_nagalikar
Try going to this address http://www.computerfileextensions.com/file-extensions.php/TSF
I hope this website helps you with the issue you are receiving :)
- Steven ASAP
Apr 21, 2011 | Computers & Internet
Unable to read massage 0 for update in tally ERP 9
Step 1
open drive where data is save
after it open your company data folder
than you have find a file (TMESSAGE.TSF)
it's error code 0
select this file and deleted its
after above process 100% your problem solve out
Dec 09, 2010 | Office Equipment & Supplies
Looking at new freezer, what is the difference between Turbo air TSF-23sdr and TSF-23nm? product specs would not download. thks
Do you mean the MSF-23NM and the TSF-23SD? If so, you can find the information for them here:
http://www.turboairinc.com/TB-Products/Soliddoor.html
Basically, the difference between the two is that the MSF-23NM runs on more amps and is a new "maximum" series that Turbo Air came out with.
http://www.missionrs.com/MSF-23NM.html
http://www.missionrs.com/TSF-23SD.html
The product spec sheets at the two links above should be easy to download from our site. If you have any trouble, you can call us at 1(800)319-0690.
Sep 22, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Is the Tubo Air TSF-49 a manual defrost and if so; can it be converted to auto defrost control?
it is automatic. If it is not going into the defrost mode, the defrost timer may not be working.
May 16, 2010 | Turbo Air 49 cu. ft. / 1388 liter Upright...
Computer won't boot or won't even enter setup
Try disconnecting all peripherals then boot up, except for those you need, i.e. video card, keyboard... If that doesnt work you may need a BIOS update... Refer to the picture below to find your BIOS code, the four numbers represent the date which you must use to find out if you need an update...
Apr 03, 2009 | Biostar U8668D (802700113338) Motherboard
Error in tally 7.2
This is vishu
Solutions to these problems needs common sense rather than tallyexpertise. Lets understand some feature and working of tally. Tallyprovides a backup and restore utility which collects all files of tallycompany into one file named tbk500.001. This way of tally backup iseasier to restore as this one file can be kept save and easily can berestored instead of all files in that folder. If any of the file getsmissing or gets corrupted tally data wouldn't work.
when data gets corrupted while working on tally and we are unable toopen the company then data can simply rewritten. Come to Companyselection menu. Press "Ctrl + Alt + R". Now select the company for re writing. 90% chance is that you problem would be get solved.
Mail me Your response.
Dec 21, 2007 | Computers & Internet
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
Computers & Internet Logo
409 people viewed this question
David Payne
David Payne
