Question about Sony DAV-S300 System
Standby mode I can't find any way of putting the player in standby mode. It is either on or off.
    Genius:
  • 1,175 Answers
Have you got a manual?
If not , try the Sony consumer site for your model.
Posted on Jul 07, 2008
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
Hi, I have a sony dav-sc8 dvd home theatre system and would likt to know if there is a way to make it multi region
These are the commands for the DAV-300 but hopefully they are the same for yours...hope it helps.
Region 0 is what you want, but here's all the commands for the 300 which hopefully work on the sc8 as well.
Put your player into "Standby" Mode and enter one of the following commands if
necessary,
: Remote control command Function
: [0] [RETURN] Default Default region code on the player
: [1] [RETURN] Region 1
: [2] [RETURN] Region 2
: [3] [RETURN] Region 3
: [4] [RETURN] Region 4
: [5] [RETURN] Region 5
: [6] [RETURN] Region 6
: [P. MODE] [RETURN] Only play DVD's with the selected region; auto switching
OFF
: [AUDIO] [RETURN] Default Auto switching ON
: [ANGLE] [RETURN] Enable video interference impulses (Macrovision ON)
: [SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision
OFF)
: [PREV] [RETURN] Enable user operation prohibitions* and access restrictions
: [NEXT] [RETURN] Default Disable user operation prohibitions* and access
restrictions.
Mar 17, 2011 | Sony DAV-SC8 System
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
My lg ht303su dvd player wont eject its saying locked
put the player into standby then hold down the stop button until 'unlocked' appears
Nov 13, 2010 | LG HT303SU Theater System
The put in standby. After turning on
If the set goes to the standby after powering On then the fault can be with the power output section. This can be a protect mode that is not allowing the processor to go further as there is a high current drain indicated on the processor.
you will need to disconnect the speakers and check .Also remove Powers to the outputs to confirm.
Attempt only if your are versed with the electronics's.
Nov 01, 2010 | Onkyo LS-V950 System
Is there a code for multi regions for sony hcd s300
Put your player into „Standby“ Mode and enter one of the following commands if necessary:
[P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF
[SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF)
[NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions
* The DVD can no longer prohibit you from using the fast-forward, chapter change or Audio-/Subtitle-/Angle switch. You can no longer be forced to watch intros. Just press [TITLE] or [DVD MENU] and select PLAY.
Jan 12, 2010 | Sony DAV-S300 System
When i press power on it says push power to protect.When i press power it says standby and then powers off.
the unit has put its self into preotect mode for a reason.
you can trr unplugging the dvd plyer from the wall, that should reset it
May 03, 2009 | Sony MHC-ZX70DVD System
Sony dav dz100 won't eject dvd
Press standby button to turn on the set, select dvd function then press and hold STOP and EJECT button for five seconds or more to UNLOCK cd slot. You will see UNLOCK in display.
Jan 02, 2009 | Sony DAV-DZ100 System
Bose 321 System Stuck on Hotel Mode!
Hey, try this out
-Press Enter and On/Off on the media center , on standby mode
-now hold the enter button pressed and start pressing the On/Off button. You should see a setting display on the player. The setting on display should change from video....till...Hotel Control -ON
- on that position, press the Volume 'minus' button on the media center. It should change to Hotel Control - Off.
Thanks
Brigade
Sep 25, 2008 | Bose 3·2·1 II System
DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
May 04, 2007 | Pioneer HTD-330DV System
Sony DAV-S300 System Logo
121 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
