Question about Ovens
Belling 4000. year 2000. no manual. thermostat only in numbers not temp. is there any guide as to what number is what temperature?
5 Suggested Answers
  • 417 Answers
SOURCE: Faulty Oven
Have you tried www.appliance-parts.co.uk, they have a useful parts finder service.
Posted on Nov 30, 2008
TheMobilian
  • 8220 Answers
SOURCE: i need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
Posted on Jan 28, 2010
SOURCE: translate temp gauge numbers to degrees
I recommend you buy a cheap oven thermometer and check the oven temperature yourself. As a gasfitter I know temperature conversions (numbers to degrees) are approximate and I think may be done on purpose so consumers won't complain if they put a thermometer int he oven and it differs from the thermostat. Check the temperature in the centre of the oven. do not use pans and trays that fill the sheld as gas ovens need room to circulate the hot air. Also do not place items in the oven so the top of it is near the top of the oven - otherwise it will burn. I have found when cooking a chicken it needs to be turned otherwist the bottom of it may not be cooked.
Cheers
John
Posted on Mar 01, 2010
Testimonial: "OK will do that next time I am in town. I know all ovens are different I just wanted a rough idea so I dont ruin too many meals!!"
bugoy31
  • 1238 Answers
SOURCE: model number for belling double
Like other kitchen appliances, your belling double oven contains a model number and serial number printed on a metal plate. The model number identifies the belling double oven. The same model number is found on any belling double oven in a specific line of ovens. The serial number is an individual alphanumeric number that, along with the model number, is required if you need to order parts or service for your belling double oven.
Instructions
  1. Locating the Model Number on the Model Number Plate
    • 1 Turn off the oven if it is on, and let it cool.
    • 2 Pull the broiler pan out of the bottom of the oven
    • 3 Lift up the front edge of the broiler pan. Lift up the rear of the pan, and pull the pan straight out.
    • 4 Use a flashlight to locate the metal plate on the body of the oven. The plate is under the space where the broiler pan was.
    • 5 Write down the model and serial number on a piece of paper for future reference.
    • 6 Reinstall the broiler pan by placing the pan onto the tracks and sliding the pan in.
    Locating the Model Number in the Owner's Manual
    • 1 Locate the owner's manual for your Maytag gas oven.
    • 2 Look at the front cover of the manual. The model number is printed on the cover.
    • 3 Write down the model and serial number on a piece of paper for future reference.
    • 4 Store the owner's manual in a safe place.
Hope it helps,,..
Thanks for using fixya...
Posted on Aug 12, 2011
My belling electric grill seems to be over heating when I've only got it on number 2
Electric elements overheat when:
1.) The temp. sensor has failed
2.) The element is improperly grounded/shorted to ground...
3.) The knob is loose and not indicating the actual setting
Jun 25, 2016 | Belling Ovens
How do i change the temperature gauge on my belling XOU176SS
I use this site a lot for my "shade tree mechanic abilities". www.repairclinic.com just enter the model number and it give diagrams and trouble shooting help. Also parts online.
Apr 04, 2014 | Belling Ovens
I need correct temperature readings
Jan 28, 2010 | Ovens
Translate temp gauge numbers to degrees
Cheers
John
Nov 30, 2009 | Ovens
Faulty Oven
Nov 30, 2008 | Ovens
Oven temperature only gets to within 20-25 degrees of temp. set
next to last page in your manual
Adjusting Oven Temperature
Oven temperature has been factory calibrated and tested. If
oven consistently over or under cooks food, adjust thermostat.
Oven temperature can be increased or decreased 35°F. To
avoid over adjusting oven, move temperature 5°F each time.
1. Push BAKE pad.
2. Press + pad until an oven temperature greater than 500°F
shows in display.
3. Immediately push and hold, approximately 5 seconds,
BAKE button until “00” appears.
4. Press + or - arrow pad to adjust oven temperature.
• To increase oven temperature (for a hotter oven), Press
pad until a positive number appears in display.
• To decrease oven temperature (for a cooler oven),
Press pad until a negative number appears in display.
5. Press OVEN CANCEL pad to save adjustment.
• Setting is saved if power fails or is disconnected.
heres a link to the entire manual if needed
http://shop.amana.com/assets/pdfs/literature/32103601.PDF
Nov 27, 2008 | Amana AOCS3040SS Electric Single Oven
Kuppersbusch EEB9800.0 oven - thermostat sensor defective
you need part number 165047 cable harness and part number 161629 thermostat pt1000 call currys partmaster and get a quote on the parts
Aug 26, 2008 | Kuppersbusch EEB 6800.0 JX Electric Single...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
