Question about Canon CanoScan 8000F Flatbed Scanner
Unplugged scanner usb while shutting down computer and now scanned photos are pixilated
  • 876 Answers
Try reinstalling the scanner software.
Turn off the scanner and disconnect it.
Uninstall the old software.
Reinstall the software and connect the scanner to the PC.
Posted on Dec 29, 2010
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
How do i get the scaner to work on my hp2610
Hi Good day!!!
The way it works for me (different HP all-in-ones, earlier photo smart) is I start Photo Smart, then (once it's loaded), I press the Scan button, and it scans (or brings up a scan menu on the little LCD on the scanner where I tell it to scan).
If this is what you're trying and it doesn't work, you might not have installed the software correctly. The scanner drivers are very picky about when you plug in the scanner to the computer during installation -- if you plug it in before the install program says to do it, the scanner won't work (though the printer will).
The thing to do in this case is (1) unplug the USB cable from the back of the computer, (2) go to control panel->add/remove programs, and remove the scanner drivers, (3) shut down and restart the computer (very important), and (4) put the HP CD into the computer and reinstall the scanner, only connecting the cable to the computer when the program tells you to do it.
Don't forget to vote thanks!!!
Nov 02, 2010 | HP Photosmart 2610 All-In-One InkJet...
Software installed successfully. Scanner will not scan. Troubleshooting Assistant insists an error occurred during installation of device. It also says Epson Perfection V500 Photo does not pass...
Try shutting down your computer and then unplug from the power source. Wait a minute then plug it back in and turn on the computer.
Accept the driver installation even though it does not pass Windows Logo testing. Just accept it and continue with the installation.
Oct 05, 2010 | Epson Perfection V500 Flatbed Scanner
My computer and scanner intermittently can't communicate. I am mainly scanning in photo transparencies at the moment - four at a time, using the "professional" setting in the software. Typically it...
I had that problem. I was using the USB ports that came with my computer. I added an IDE USB card in my computer. I haven't had a problem since.
JNHV23
Jan 10, 2010 | Epson Perfection 3170 Flatbed Scanner
Won't scan photo to computer.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | HP Photosmart C4280 Aio Printer
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Please rate!!
Jul 17, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanner & Copier doesn't work
If you get this error when trying to scan from the computer try starting the scan directly from the device and see if that works. If not, unplug and replug the USB cable(assuing you are connected to the computer via USB cable) and install the driver, if you get any plug and play prompts. Let me know if this doesn't work.
May 06, 2009 | Lexmark X5470 All-In-One InkJet Printer
Scanner will not calibrate.
Make sure your scanner is connected to your computer with a cable or over the network. Scan your calibration target and save it as an uncompressed TIFF file.
Open the Activities overview and start typing Color.
Click on the Color to open the panel and select your scanner.
Jul 01, 2017 | Umax Astra 1600U Flatbed Scanner
Minolta Dimage Scan Dual III Problem
Chances are you have a Twain conflict. Unplug all other items that use usb ports. Restart and then see how it goes.
I have not had trouble with this while using my Dimage scan 3 but had horrible problems similar with other scanners...took me forever to understand this.
Hope it helps.
Dec 03, 2007 | Minolta Dimage Scan Dual III Film Scanner
Canon CanoScan 8000F Flatbed Scanner Logo
old marine
old marine
