Question about Sharp Multi-System Mini Component System Shelf System
When i plug my radio(cd-m10000) show protect - Sharp Multi-System Mini Component System Shelf System
Why is there sound output when using am/fm but none when playing a CD?
Internal radio problem. There are two plugs for the CD in the radio. One for input/power. The other is for output/sound. If it is an expensive radio, pull the case off, look at the CD player and find the plugs to the main board. Unplug them and plug them back in, hook up the radio and see if it works.(could be that simple) Then reassemble the case. If it factory or cheap, just replace it with an aftermarket radio. This would be cheaper than an electronic repair.
Apr 11, 2015 | 2001 Nissan Maxima
I mis placed the power amp ic for my sharp model number cd-m10000 what is the ic pert numbery
You can get the IC specifications if you can refer to the Sharp service center with the model specified as the OE part will also be available with them.
Mar 11, 2012 | Sharp Multi-System Mini Component System...
Power on, few second automatically shut down in sharp video cd mini system. model # CD-M10000
hi,
speaker output amplifier of u system may be damage. that's why it goes off. check the out put amplifier.
ok
Jan 11, 2011 | KLH (AT2100) System
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
Why does my radio say protect
Protect indicates that there is a short or a grounding problem usually within the speakers or the speaker wiring. Locate and press the reset button (pinhole). If protect comes back then disconnect all speakers, reset and connect them back one at a time until protect shows up again. This will help you find out where the unwanted DC signal is coming from. If protect shows up when all speakers are disconnected, then it may need service.
Apr 11, 2010 | Kenwood KDC-MP205 CD Player
After reconnecting the car battery, the radio would not turn on
The pioneer has a small protection fuse in the back of the radio, alot of time when it catches a power spike, it will blow to protect the head unit. It should be plugged in the back of the radio under the main plug. Hope this helps.
Aug 20, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
MP3 player-shows no files downloaded
k the whatever may be the problem i suppose its a virus affected device. format your device in a protected computer and upgrade it using the firmware manager that came in the form of installation cd.(you need internet to upgrade . this will solve the problem i beleive.
Jul 04, 2009 | NexxTech (20-8002) SW/FM/AM Radio
Protect on the screen.
PROTECT shows up on your screen when one of the speaker wires is grounding out on something. Check all the speaker wire connections and re-insulate any that may be suspicious. Look behind the player and check those and you may have to check at the speakers as well. If your car has an amp or subwoofer installed, check at the connections there as well. After finding your grounding issue hit reset on the radio and you will be up and running.. Happy listening. K
Jun 06, 2009 | Kenwood KDC-MP232 CD Player
My boombox is displaying the word "Protect" in the display. ???
The protect message indicates that there is a problem with the final stage of the amplifier section. This unit will require repair as a reset will not clear this. There is an audio amp IC inside that needs to be replaced. Figure on about $15 or so for the part.
Dan
Dec 09, 2008 | Sony Boom Box With CD Player & Cassette...
Kdc mp438u
it says protect meaning one of the speakers is shorted troubleshoot my speakers all were good put my old radio in everything worked put the kdc back in verified that the radio is bad took back to best buy interchange for a pioneer for about 60 more
Jul 03, 2008 | Kenwood KDC-X590 CD Player
Sharp Multi-System Mini Component System Shelf System Logo
48 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
