Question about Bosch Refrigerators
My BOSCH refrigerator does not cool the food KGU4077IE/02 is the make. Can I try soemthing before I call the expensive repair man ??
HVACRH20
  • 237 Answers
SOURCE: Problem with fresh food side of my refrigerator freezer
The bulbs dim glow is a worry, sounds like not enough voltage is getting there. If you are comfortable with a multimeter, check what the voltage is at the bulb socket. If you have a low voltage issue due to say the transformer not working properly then the fan will also have low voltage (or no voltage). No power, no fan, no cooling. I'd suspect there are voltage issues with that transformer, especially since it's a 240 VAC model. A transformer typically steps down the 240 volts to 120 volts for light bulbs and maybe even the fans (or the whole refer). The repair man may be correct in that the transformer is built in to a circuit board but it COULD be a stand alone transformer.
Posted on Nov 10, 2006
erpaalai
  • 999 Answers
SOURCE: Kenmoe 596 not cooling
The repairman is correct to a point. It may be a weak compressor also but either way the repair is in the sealed system and extremely costly. Sorry to bear bad news. Eric
Posted on Aug 10, 2009
  • 159 Answers
SOURCE: refrigerator stopped cooling, repair man said it
if the motor are still running its not enough gas but if the motor doesnt run its the thermostat
Posted on Oct 23, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator/freezer--moisture is collecting on
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: My freezer is working well, however the top
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 15, 2010
Ice forming
  • One cause of this is the compressor is going bad or Freon is low. The freezer is no longer able to achieve the zero temperature requiring the compressor to run continually. The refrigerator because of the continues running begins to freeze up. Food in the refrigerator begins to freeze and the freezer is not as cold as it should. This results in a very expensive repair of replacement of the unit .
  • The defrost cycle is not working. Depending on the conditions the unit has a sensor that detects when the defrost cycle should initiate. If this fails to occur than ice builds up on the coils and air can no longer pass preventing the normal cooling process. Many models use a mechanical timer that stops. On some units the defrost cycle can be initiated via advancing the mechanical timer. This repair is a reasonable expense.
  • The third possibility is a door was left open and the unit iced up the cooling coils. Suggest in that case shut off the unit , remove the food and allow the unit to manually defrost, Restart and see if unit gets cold and defrost cycle is working.
Nov 22, 2015 | Refrigerators
2 year old Bosch B22CS is not keeping temp low enough.
Check the condenser on the bottom back side of the fridge if it is plugged off the freezer will not cool enough. If the condenser fan motor is dead then the freezer will never cool down enough. If that doesn't do it then you are looking at a waxed up cap tobe in which care you will need a professional to take care of the problem. Good luck
Sep 08, 2012 | Bosch B22CS30SNS (22 cu ft) Side by Side...
Bosch FD8709 Fridge Freezer (American Style) Freezer section not cooling (Ice maker has stopped making cubes and food starting to thaw) Fridge section seems to be working OK..! In Manual says that the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2011 | Bosch Freezers
Our bosch side by side with freezer is not cold at all, foods in the top & second shelf in the freezer are not hard frozen as it used to be, we have tried to reset it by switching the main power off...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Dec 27, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
The refrigerator is not cooling
If your freezer is frosting up, fresh food section is warm: bad fan motor,defrost drain stopped up and forming slab of ice between the freezerand the fresh food section. Check heaters andterminator(defrost thermostat) unplug the ice box and let it defrostcompletely. Clear objects from drain. Check timer. Note to find thelocation of your timer look up your model number online here: APPLIANCEPARTSPROS.COM.
Check under the bottom for the fan motor to be running and the cobwebs, dust, dirt, and pet hair, off the condenser coils. If the fanunderneath has quit then the ice box won't get cold. BASIC REFRIGERATION REPAIR MANUAL
AMANA SxS REPAIR MANUAL
BOSCH MANUAL
Monogram Manual
KitchenAid SxS with variable capacity compressor
GE LATE MODEL SxS MANUAL
F&P Reefer
Jan 11, 2010 | Maytag Refrigerators
Aug 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Oct 29, 2006 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
73 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
