Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
The machine will not fill. There is a humming sound like its about to pump the water, and then nothing. Help!
  • 1,557 Answers
If there is humming thats the sound of the valve ( water inlet opening) I DONT WANT TO SOUND SILLY BUT IS THE WATER TURNED ON it happens
take care
sonic boom electronics australai
Posted on Dec 29, 2010
Machine starts fills Ok but when it clicks on to start the wash pump, nothing happens, I can hear a faint hum. When cancelling wash and starting new wash it pumps out ok too. After rinse cycle it indicates...
sounds like your main circulation pump is not working, if it is humming when it is supposed to start, sounds like it is getiing power, so probably not the control circuits, can you measure voltage to pump?
if you are getting 120 there, probably pump motor is dead
Mar 02, 2013 | Asko D1876 Dishwasher
MY GE front loader washer won't fill with water or spin. I hear a hum when I turn it on and it sounds as if it's about to start a cycle but nothing happens.
It sounds as if your water valve is either clogged or the solenoid is stuck and not letting any water in. Here is a checklist of things you should do to help isolate the problem:
1) check to make sure the water is on
2) turn the water off and remove the water lines and verify that both the lines and the screens on the valve are clear of debris, calcium, etc.
3) take the top off the machine where you can actually see the valve, turn the machine on and see if the vavle is the humming noise that you are hearing. If so and no water is coming out then the valve is bad.
May 19, 2012 | GE Washing Machines
A few days ago our sink/garbage disposal was plugged up - plunged it and opened drain BUT dishwasher started humming and wouldn't fill up with water. Bosch Model SHU43C06UC Tried pushing on/off...
Check the drain pump it is located in the front of you unit .Disconnect power or flip breaker .Remove the front kick plate then there is a metal plate above that is held on with 4 screws remove that and reach in and press lever on pump and turn counter clockwise it will come right out .Then check for items in the pump area could be glass. Hope it is helpfull
Sep 18, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
GE adora fills up with water but will not wash. I here that humming sound.
That sounds like a problem with the pump. Remove the strainer panels at the bottom of the machine and check that there is nothing in the pump that is jamming it. Do not try to run it like this, the pump motor will burn out.
Feb 02, 2011 | Dishwashers
My washing machine will fill up with water but it will not agitate or spin to drain the water all it does is make a humming sound like its trying to and if I let it hum for a while I start to smell...
This is most likely going to be something hung in the water pump. On this pump I end up changing the pump because it is hard to get it unclogged without damaging the pump. This page should help. http://www.appliance-repair-it.com/Whirlpool-washer.html
Sep 16, 2010 | Kenmore 22932 Top Load Washer
Fills up with water then nothing **** a humming noise
sounds like something stuck in pump or bad motor.
my bet would be something in pump,
Sep 01, 2010 | Estate Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
