Question about HP LJ 3020 All-In-One Printer / Scanner / Copier
Unable to load 3020 scanner driver - HP LJ 3020 All-In-One Printer / Scanner / Copier
2 Suggested Answers
  • 1739 Answers
SOURCE: I have HP 3020 all
You can find drivers here for your printer model and your operating system:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=378053&
Make sure you download the correct version for your computer; 32-bit vs, 64-bit.
To check your operating system, click on Control Panel; then select System.
View the System type to confirm whether you have 32-bit or 64-bit installed.
Posted on Dec 22, 2010
My odl hp 3052 scanner drive cd is not compatabel with win 7 kindly suggest
Hi
The Hp LJ 3020 is compactable with windows 7, Click hear and install the windows os driver.
Jun 10, 2011 | HP LJ 3020 All-In-One Printer / Scanner /...
Have Canon DR-3020 scanner. Installed, everything OK per Device Manager. ScanGear recognizes scanner and scans but Capture Perfect does neither. Any ideas?
I have worked on Canon scanners for many years and I am very familiar with the scanner you have now. That model of scanner will not work like a convential scanner do to its age and compatibilty with todays software. I have found a website that will allow you to download capture perfect to use on your scanner. If you continue to have problems you might want to email Canon directly to ask for a link that will be more specific to your scanner. Just remember when that scanner came out Windows 95 was state of the art for software. Since that time Microsoft has gone through several upgrades to windows. Here is the link and if you need any thing else let me know. I am very good with your model of scanner. I hope this helps you out.
http://www.driversquad.com/driver.php?option=o&prodid=60&cust=canon+scanner+software_AD_www.google.com_&channel=&subid=201_US*DR_o&roia=!iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
Mar 18, 2011 | Canon DR 3020 Path-Through Scanner
Hi got the following error message ... "ScanFile
I have many years repairing canon scanners so here is my suggestion to you.
First does the scanner power up? If so that's eliminates a internal power supply problem.
Second did anyone change the dip-switch settings on the back of the scanner? Ill assume no on that one.
Third when you first boot up your computer do you see a screen when the computer is in boot up mode that says Adaptec SCSI and then a number? If not here is a couple things to check. First I would check the SCSI cable is good. No bent pins in the connector and no exposed wires coming out of the connector. If you can try swapping a good known working cable with the problem scanner. Second try re seating the SCSI card if that doesn't work do you have another card that you know works that you can swap into the problem computer. After swapping the cable first test to see if the scanner scans, then if you replace the card again retest to see if the scanner scans.
Lastly and I have seen this happen, the drivers may get corrupted if new software is installed that relates to scanning. You may want to google DR 3020 drivers that should pull up Canon's web site and reinstall the drivers. Once you install the latest drivers then reboot the computer and test it to see if it now scans.
Im sure one of my suggestions should correct your problem. I hope this helps you out.
I have HP 3020 all in one printer. I am able to install printer drivers successfully, but unable to complete scanner driver software. I am using windows 7. Please suggest suitable driver.
Dec 22, 2010 | HP LJ 3020 All-In-One Printer / Scanner /...
I cannot load the software on my laptop. I have
Please open the "paint". For open it clik on "start/all programs/accessories/paint".
Click on scanner and camer wizard if it hilight, and click on scan to scan the document, if it is not hilighting"scanner and camer wizard" it means it is not detction to scanner, then you will have to download the latest driver from hp websites and install it.
Nov 04, 2009 | HP LJ 3020 All-In-One Printer / Scanner /...
I have a canon xerox machine model 3020 copy is not comming,blank white paper is comming
Canon 3020 is a scanner, not a copier. It can scan a document & store. If you print the image, you will get a 'photocopy'.
S. Mohan
Sep 18, 2009 | Canon DR 3020 Path-Through Scanner
Canon DR-3020 Scanner with Windows XP Pro
Download Dr 3020 drivers for XP from http://software.canon-europe.com/products/0000666.asp
Try connecting the scanner to a diff computer and check if it is okay. Also pls ensure SCSI termination is okay.
S. Mohan
Jul 09, 2009 | Canon DR 3020 Path-Through Scanner
Vista & Canon DR-3020
As per CAnon Europe site, it looks only version 3 of CapturePerfect works in Vist environment. What version do you use?
There is no mention about ISIS/TWAIN Drivers. In case you can load the drivers, you can try Microsoft Imaging to scan instead of CapturePerfect.
S. Mohan
Sep 10, 2008 | Canon CanoScan DR3020 Path-Through Scanner
HP LJ 3020
The scanning unit is faulty, u may trying cleaning the scan unit ,else it needs replacement.
Happy printing
Omnipresent
Oct 17, 2007 | HP LJ 3020 All-In-One Printer / Scanner /...
HP LJ 3020 All-In-One Printer / Scanner / Copier Logo
207 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
