Question about Maytag Washing Machines
Washer has stopped spinning, also the unit will have time left on the timer and it shuts off
    Scholar:
  • 148 Answers
It is the door switch,the pin on the door pushes a swith when you close the door as a safety this is installed so the washer doesnt spin while the door is open,open the door you should see 2 screws which hold it up
Posted on Jul 07, 2008
  • derek martin Jul 08, 2008
    try taking a screwdriver or pen and push on the switch while its on the spin cycle,try it several times cause it may work a couple of times then not work,let me know if this is the problem before we go to step 2
My washer is stopping and not spinning with about 12 minutes left on the timer. Is it time to get a new washer or is this problem fixable?
""is this problem fixable?"" Yep just need to know your model number. Is it a FAV6800A or FAV9800A?
Any error code to the display?
Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800AW Top Load Washer: my washer is stopping and not spinning with about ...
See if my Clutch Fix post will get you started if your machine model type is a FAV6800A or FAV9800A……Rich
May 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
It gets through to the 40 minute part of a cycle and shuts off and unlockes door and has ol code
This kind of problem is usually when the final spin is overloaded and the overload sensor stops the spinning. But, this can also happen during the spinning at end of wash cycle. Does this shut-down occur every time? If not, then it is your load that is too much. If it happens every time, then it is most likely the overload sensor. The electronic timer could be the problem (they are more flukey than the mechanical timers) but usually you will not see OL if the timer itself is at fault. Good luck, Macgivor.
Dec 27, 2009 | Maytag Bravos MTW6600T Top Load Washer
WASHER SHUTS OFF BEtween wash cycle and rinse
Sounds like you have a bad timer. Simply purchase the timer. Remove the screws on the backside of the control panel and remove the defective unit. Replace the timer keeping careful attention on the placement of the original wiring. Also, when you have trouble with the unit not running for rinse and spin cycles, it is generally a good idea to replace the lid switch as well.
Jun 27, 2009 | GE WBSE2090A Top Load Washer
Hotpoint Dryer Heater stays on when door is opened
Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Frigidaire front loader wont final spin timer stops at 7 min.
its_me_ac You probably have a faulty timer switch.
You can buy parts at this site , v
Please give me a good rating
Dec 05, 2008 | Frigidaire ATF6000ES Front Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Kenmore 94802 - Goes through all cycles.. Doesn't stop after last spin cycle.
I hate to say it, but it sure sounds like a timer problem. There are contacts inside that move and switch items no matter what setting its in. Its a possibilty that the power contact is stuck closed and when you manually turn it off it breaks contact. The job to replace is really not that hard, remove console (unplug unit first), mark your wires, then just replace. The part though is a touch expensive (131789200 Sears Part Number). Probably would be a little cheaper than buying a new unit I guess. Let me know if you need any further information. Jim
Nov 04, 2007 | Kenmore 94802 Front Load Stacked Washer /...
Washer would not stop
danby parts department: 18000-496-6049
i found the timer for this model: DTT420
timer part # 420.4.05
can be bought for cheap at www.partstop.com or www.topapplianceparts.com
----china part #-
DXT-15f-G
120V 3A AC 2008y10M
Aug 07, 2006 | Frigidaire FWSB7800DS Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
