Question about Asko W660
Door won't open. tried to turn it on and off.
  • 876 Answers
Try a hard reset of the op system by unplugging the machine and waiting a few minutes then plugging it back in. If this does not work, your door lock mechanism may need to be replaced.
Posted on Dec 29, 2010
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
Accessories won't turn off when driver door is opened but does turn off when passenger door is open
there is a switch in the door hinge its wore r derty spay hinge with blast away r wd 40 if it dosnt work the switch will need replaced
Jan 20, 2013 | 2002 Buick Rendezvous
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
97 Mercury Mountaineer driver side door won't open. Outside handle flops around; inside handle won't open door
Try a slim jim first, down the side of the window. Or AAA or locksmith. If no luck, remove the seat first. Find the screws and bolts around the door handle and arm rest. Most Ford's have screws around the outer side of the panel. I don't believe your's does. The panel lifts or pops off. Once the panel is off, you can reach down and open the door. Just a note. I have done some to where the panel came out in pieces.
Mar 14, 2012 | 1997 Mercury Mountaineer
My lights won't turn off in my car when I lock it and there's also no honking noise. Then a few minutes later the alarm will go off. If I leave it unlocked the alarm doesn't go off but the...
its the door switches they are sticking and telling the car door is open. open and close both doors a few times and make sure they are closed good and try again to make sure it is setting properly you will know cause the care dome light will go and it will emit a short honk when activated!! =) mine just did the same thing
Oct 11, 2011 | 2006 Saturn ION
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
I have a Pentair MiniMax NT. I am getting ERR on the display but I can't seem to get the door open. I have tried turning the single screw that locks the left and right door but it won't unlock.
sometimes the door is just stuck. try pulling the door as you turn the locking screw. sometimes you need to use a flat head screw driver to help the door open as you turn the screw back and forth
Jun 11, 2011 | Pentair Minimax NT Heater
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Washing Machines Logo
163 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
