Question about Primax Electronics HT2778P TV
Hourglass Picture Turned the TV on in the AM and the picture appeared with an hourglass shape where the vertical center of the picture is in about 1 1/2 inches on each side. I checked the menu structure but there does not appear to be an adjustment for this effect. Thank You
  • Thomas Kainz Jul 08, 2008
    ALSO...
    Because we live so far out in the Colorado Mountains I opted to "play" with the settings and to make matters much worse, I did something I know that I shouldn't have and that was to get into the service menu structure and fiddle with the settings to try to correct the problem. I ended up modifying the wrong setting whereby the picture immediately went to black and upon restarting all I now have is a blue screen with thin white horizontal and vertical stripes fluttering through it. Now, in addition to my original question / problem, I have to ask..is there a way to reset the tv's service menu back to the default settings. I have no problems getting into the guts of the beast so to speak if that is necessary although I really don't have any testing equipment to speak of.
    Thanks again.
    Genius:
  • 2,035 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
This is one of the ways to restore the factory settings
Good luck......
Posted on Jul 08, 2008
    Brigadier General:
  • 3,614 Answers
Can you please identify the unit model/maker
  • micromaster
    micromaster Jul 08, 2008
    as my initial info here.. try to unplug the TV for 72 hours to reset the settings...
    let us know again here...
It has an hourglass shape when first turned on but
Your TV set has trouble in its "pincushion correction" circuitry, which corrects distortion so the picture is straight on the screen. Unfortunately, it's not possible to pin the trouble down to a specific part without having the set for troubleshooting. Since the trouble clears up after the set's on for a time, it's probably due to a faulty capacitor or intermittent solder connections. Because of the troubleshooting skills and tools needed, you should let a professional service shop handle the repair. This kind of problem is relatively inexpensive to repair (at least parts-wise; I've been out of the repair business for a while now, and have no idea what kind of labor prices shops are charging) and would not cost nearly as much as a replacement TV.
Sep 24, 2009 | Panasonic CT-35XF53 35" TV
Picture is smaller, has hourglass shape, no sound
Took back off, removed control board and inspected for bad solder joints. found no obvious problem. Cleaned and reinstalled. Working ok now. I'm crossing my fingers.
Jan 27, 2009 | Philips Magnavox TS3260C 32" TV
Hourglass shaped picture on rear projection Hitachi 48 inch older
you will need to take the TV and have them diagnosed it for you.
Dec 05, 2008 | Sprint Hitachi P300 Cellular Phone
Philips 25PT2252
Vertical hold will adjust the frequency (refresh) which would remedy it if the picture was rolling. I had to open up my TV (not recommended unless you know what you're doing) and adjust a "pot" which will adjust your screen's hourglass problem. I hope this helps.
Jun 28, 2008 | Televison & Video
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Magnavox 51mp392h
replace the convergence ICs STK392-120 you will need both of them also check the 6.8 ohm resistors right next to the ICs as often 1 or 2 of them burn open. You should be able to notice the discoloration in the center of the resistors.
Mar 11, 2008 | Philips 60PP9202 60" Rear Projection...
RCA 32V432T picture problem
Sounds like the Filter Cap is shorting.
Sep 08, 2007 | Televison & Video
Hourglass Picture
Pulling in from the sides usually results from poor regulation or width problems related to the horizontal circiut. These are not usually repaireable by a non technician.
Aug 06, 2007 | Toshiba 27D46 27" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Primax Electronics HT2778P TV Logo
203 people viewed this question
Top Primax Electronics Televison & Video Experts
Electro Med Services...
Are you a Primax Electronics Televison and Video Expert? Answer questions, earn points and help others
