Question about Fujitsu Siemens Standard 172E (White) 17" CRT Monitor
Horgental 17 crt problem not increes - Fujitsu Siemens Standard 172E (White) 17" CRT Monitor
Hi, My DELL 17' CRT Monitor is not getting power suppply. Please help me out for the same. Kart.
Spend $50 (or $100) and buy a used (or new) 17-inch LCD monitor, rather than "investing" $50 to $75 to pay a TV/video technician to *TRY* to fix your CRT monitor.
Sep 24, 2010 | Dell E773C 17" CRT Monitor
Hi what is the model number for an e70fb backlight? i need to replace
ViewSonic E70fb 17" CRT Monitor, it is not LCD flat panel monitor, it does not have backlight assemblies. It uses picture tube (CRT).
Are you asking about ViewSonic E70fb 17" CRT Monitor problem or other model?
Sep 06, 2010 | ViewSonic E70fb 17" CRT Monitor
Sir i have 17' crt monitor and it gives display as shaking condition .. Could u give me some solution abt that ..
make sure u dont put speakers near ur monitor and any other electrical equipment that can generate magnetic field. (eg. UPS, stabilisers...).
May 19, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
My hp vf15 monitor flickers on and off when it is plugged
17-inch CRT?
Ask your friends -- one of them probably has a "surplus" 17-inch CRT that they will _love_ to give-away to you, to replace yours.
Or, look on CRAIGS LIST for a used 17" LCD screen, for $30 to $40.
Jan 14, 2010 | HP Pavilion MX75 17" CRT Monitor
What component failed in my 17"CRT 753s model samsung moniter?
Your vertical deflector circuit is going out. This is really not economical to repair, the chip alone is $12-15 plus if you have any other parts in the circuit going out plus labor. You can pickup 17" CRT monitors for less than $15 from goodwill or craigslist.
Sorry to say but I think its time to retire your 753s
Buddy
Corporate Computer
Jul 14, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
I need the elctronic layout of monitor lg flatron 775ft
TYPE THE FOLLOWING INFORMATION
WWW.MFG NAME.COM/SERVICE
WWW.SCHEMITICS LG FLATRON 775FT [WHITE] 17" CRT MONITOR
ENTER
LG FLATRON 775FT 17" CRT MONITOR SCHEMITICS
OR
LAYOUT
ENTER
May 12, 2009 | LG Flatron 775FT 17" CRT Monitor
Hp laserjet 1100 - won't print under Win'98SE i've got this printer and can't use it on a computer under win98SE. under XP works fine! all the ports seems to be bussy, and request to increes the timeout...
Try changing the LPT port mode in the BIOS- there should be like SPP, EPP, ECP. As I recall there are different drivers for USB and Parallel and I don't think Serial is supported. If you installed HP drivers, Uninstall and use the Windows drivers.
Dec 07, 2008 | Office Equipment & Supplies
2SC5589 in LG 17" CRT Monitor
This transistor is manufactured by Toshiba and is only available through Gateway.
Dan
May 07, 2008 | LG Flatron 776FM 17" CRT Monitor
Dispaly settings for samsung 794 MG 17" CRT
can u send me the wat is in the setting menu of your monitor?
Dec 16, 2007 | Samsung 793DF 17" CRT Monitor
Dell P780 17" CRT Monitor(3 yrs old) issue
That sounds like a monitor issue, not a video card. Gradual fading means components within the monitor are wearing out. However, I strongly advice against attempting repairs. CRT monitors hold a strong electrical charge. People have been injured and even killed by attempting to work on them without proper tools and training. A 17" CRT monitor is too cheap to be worth the risk (you can often get them used... I got mine for $20 at Goodwill).
Aug 22, 2007 | Dell P780 17" CRT Monitor
Fujitsu Siemens Standard 172E (White) 17" CRT Monitor Logo
43 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
