Question about Toshiba Computers & Internet
I wantr to view movies from my Tos. lap. top directly to Our Tv ?I have Video wire on both units
  • 1,879 Answers
Greetings,
You just need to activate (turn the video-out port) of your laptop. It defaults to off to save power. Check your manual for combination keys to turn ON the video-out port.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jul 07, 2008
    Sergeant:
  • 233 Answers
* use the tv out port from pc to tv
* connect sound out jack to tv sound in
Trouble with viewing my movies on tv direct from jvc everio gz mg37
Are the recorded movies in a format compatible with the TV ? They may need to be converted to MPG or MP4 format before the TV will recognise them.
May 04, 2016 | JVC Video Cameras
My (Cable Service) wire feed is directly behind my HDTV and hooked up over my fireplace . The Rxv667 is located on a side wall book shelf. I have A HDMI wire running to the TV from my receiver. Do I need...
Is there a set top cable box, or are you feeding the cable directly to your HDTV (coax directly to the TV). If you are feeding cable directly to the HDTV then you don't need HDMI. There maybe exceptions, but most TV's don't have HDMI output. The only thing you need to run from your TV to the Yamaha is an audio cable. I assume your HDTV has an optical audio out (either TOS or coax.... Your Yamaha will accept either). Connect the optical audio cable to the AV4 input on the Yamaha. This way when you hit the TV scene button on the Yamaha remote, it will select the AV4 audio input (the default for the TV scene). The optical cable will feed the full audio signal, so that the Yamaha can pass through the surround sound or use the decoder as appropriate to feed your 7.1 or 5.1 speaker system.
If you have a set top box, you may be better off moving that near the Yamaha. In this case, cable goes to settop box, output of set top box via HDMI or component video (RGB) and optical audio to the Yamaha (if you use HDMI Input 2, and AV4 for the optical audio (if necessary), the TV Scene will select the appropriate inputs) and then an HDMI to your HDTV.
In case one, you may need to setup the TV to process the audio appropriately. I have experience with Panasonic Plasma but thats about it.
Feb 24, 2011 | Yamaha RXV667 Receiver
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
Leads for video out put from lap top to t.v
Firstly to connect your laptop to your television, all you need is the cable that connects a CPU to the monitors.
connect it to the printing port on your laptop and connect the other end to the 21 pin connection at the back of your television.
Then you select the AV channel and you will be able to do anything on your laptop using the TV as your screen as well as watching a movie.
Take care
Jul 03, 2010 | HP Pavilion dv4000 Notebook
Video cord
Make sure the TV is configured properly first off, make sure it's one of the auxilaries that are selected. Now if you haven't already, you should usually press F-something to get your lappy on dual display mode (F8 usually). If that fails, you may have to ween through some of the display properties, which isn't a big deal, but would require more of a live chat session to go through, or more info on here and some patience :).
Dec 14, 2008 | Compaq Presario Notebook
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
