I have a Dome Focal 5.1 system and a Yamaha RXA 2000 receiver. On setting up the system I get an error SW1 - Detect - out of phase for the subwoofer. The subwoofer has a humming noise.
  • 1,557 Answers
The sub has an internal power fault that needs to be repaired there is no easy fix for this
sorry
hope this helps
take care
Posted on Dec 29, 2010
Testimonial: "We took it to the dealer where we brought the Yamaha receiver - he tested it and the subwoofer was ok"
  • sonic boom electronics
    sonic boom electronics Dec 29, 2010
    then there must be a feed problem either in the rca cable running to it or the sub outlet on the amp must be damaged and restricting signal to the sub ..
    keep me up to date sounds interesting
How to solve the the YPAO warning (W-1) problem on the Yamaha RX-V367?
Step 1: Get the manual out.
Step 2: Search it for W-1.
It's only a warning that the subwoofer phase is possibly reversed which can **** some of the bass out of the room at the microphone's position. If you CAN change the phasing, try it and retest. Otherwise repositioning the sub may yield a different result or it may just be a glitch.
Use a search engine and read up on speaker phasing.
Jun 28, 2011 | Yamaha RXV367 Receiver
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
How to solve a W 1 error on a Yamaha HTR-3063
Are we really talking about a HTR-3063?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-HTR-3063-Receivers-manual/id/23653ag915/t/2/
Strangely enough, that message is NOT documented in the HTR-3063 manual, but in another Yamaha manual (HTR-5063) it means the speaker being tested is believed to be Out of Phase, meaning wired incorrectly.
Your unit (HTR-3063) doesn
Feb 15, 2011 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I tried installing a set of Def Tech Pro Cinema 600 speakers to my Yamaha RXV667. They recommend two methods. One is to connect the subwoofer through a cable using the LFE port on the receiver. I've done...
I'd go with the second method of connection for this receiver if you want to use automated calibration that requires discrete control of each speaker. I'd expect calibration errors with Method One as you're not just monitoring the sub when you test it; and the L and R fronts would have sub chiming in during the test, too. That would surely confuse the automation.
You (or the receiver) wouldn't be able to adjust the sub independently of the fronts that way.
http://www.retrevo.com/support/Definitive-Technology-ProCinema-600-Home-Theater-Systems-manual/id/15013ci257/t/2/
I'd also be a bit leary of their claim you can set your speakers to Large. With only 3-1/4" drivers I wouldn't expect much in the way of realistic bass-handling or power dissipation.
From the manual...
"We encourage you to experiment with the various settings on your subwoofer, settings on your decoder, and hook-up options as described until you find the best combination for you."
Jan 24, 2011 | Yamaha RXV667 Receiver
Speaker Err on Yamaha Home Theater Unit ???
I am assuming this is the message that shows up from your receivers front display panel? It could be the receiver is telling you that you may have the neg & pos. wires crossed and in the opposite position either in back of the receiver speaker posts, or in back of the speaker terminals themselves. My Yamaha receiver has this nice feature where it will tell you when the speakers are "Out Of Phase" which describes the problem I have described here.
Just go back and make sure your wires are hooked up correctly, and use tape and a Marker to label pos. and neg so they will be easier to hook up next time you have to move the system, or decide to change some aspect of your system. I would then take the time to label every wire that goes to each speaker that you plug into the back of your receiver. This a BIG time saver........
Apr 10, 2010 | Yamaha 5.1-Ch. Surround Sound Home Theater...
I get no bass sound from sub-Woofer connected to Yamaha RX-V465
Check your speaker settings in Setup menu / Speaker Setup / Manual / Config (and then in this submenu also Equalizer).
In Config, choose where should low frequency sound go - subwoofer and/or front speakers (if they are big enough). The settings are: Bass Out: SWFR/Front/Both.
Also check Subwoofer phrase in SWFR Phase.
Check settings of all speakers, they can be Large / Small / None. If small, frequencies lower than "Crossover" settings, will not be put on them.
Nov 13, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
Bought a Yamaha HTR-6130 doesnt sound good with my Bose. Not enough bass
Have u tried to run the setup / installation, to detect if your speaker system, have or not, subwoofer / size of speakers, etc... or run the manual setup or change the configuration of the bass. -10db + 10db
Jul 26, 2009 | Yamaha HTR-6130 Receiver
Speakers connection
There shouldnt be a problem with that at all. The subwoofer needs to be self powered. The Yamaha has a "Subwoofer Output" on the back. Just connect it there.
Apr 04, 2009 | Aiwa Audio Players & Recorders
I am unable to get the required base sound from my Acoustimass 16
Read the clues - Out of Phase means you have one or more of the speakers wired minus (-) to plus (+) instead of like pole to like pole. Having any speakers out of phase with their counterparts can **** the bass response out of the room. Check your wiring.
Apr 02, 2009 | Bose Acoustimass 16 System
Yamaha Receiver
did you find a solution?
Thanks
Mar 29, 2008 | Yamaha HTR-5630 Receiver
165 people viewed this question
 Grubhead
Grubhead
