Question about Dishwashers
Indesit dishwasher keeps switching itself off mid-cycle, may be electrical problem or on/off switch as generally works if we lean something against it to keep it pressed in. also resets itself so cycle takes longer than it should
  • 425 Answers
Try cleaning your dishwasher internally maybe something clogged up. but before that, unplugged it from the power supply.
Posted on Dec 29, 2010
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
Tip
Dishwasher How to avoid Flooding & subsequent lockup tip
So you pressed the button & turned your dishwasher off during the Cycle, to put something in, or take something out, and now it' wont do anything? Well you see, with your dishwasher you must never switch it off mid cycle to open door. You must simply just open the door, or will flood, and then mysteriously shut down. and lock up. Now when and if this happens, the way to fix this, is to lean the Dishwasher over backwards, side to side, tip it over at up to a 45 degree, angle to reset the Flood Switch.
on Feb 15, 2010 | Dishwashers
Hi Indesit IDL700 Dishwasher. Stopped mid cycle by
The main processor was interuppted and so has hung up or is faulty. Remove the main plug and press on the control pad of the washing machine to drain off any residual voltage that is remaining on the main board and which seems to have hung up the processor.When the plug is plugged in and switch please hold down the start/stop button.
If there is no result after plugging in the machine then the main controller board is a suspect. You can remove the control board and check the connectors, check the main door switch , if possible clean the connectors/ contacts as a last chance.
Sep 05, 2011 | Dishwashers
Cycle interupted until pressure applied to door, near control panel. Fault is intermittent. Sometimes I need to lean a chair against it to keep it going. Door clicks shut nicely and does not leak. Cycle...
problem on the safety switch
1)try to adjust the safety switch to contact properly with the door.
2)any screw is there on switch means loosen the screw &adjust to contact with door.
Jan 07, 2010 | Bosch 24 in. SGS43C02 Classixx Built-in...
Dishwasher not working
sounds like the heater is not working. it's washing while waiting for it to heat to correct temperature.
if you are not electrically minded i'd get an engineer out or ring one for a quote.
Jan 27, 2009 | Dishwashers
Indesit dishwasher overfilling
There are two ways that dishwashers generally fill. One is a float inside the tub, the second is a tube which fills with water, loops and goes to a pressure switch below the machine. That switch is usually about 1.5 inches in diameter, two wires and a small hose going to it. The float witch is found below the float in the motor area. With the float, sometimes they jam with too much old detergent or food goo. Clean out. Both can have the switch weld closed. Change the switch in either case. Since the unit is not filling with the power off, I'm going to guess the water solenoid is okay.
Dec 22, 2007 | Dishwashers
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
STOPS RUNNING IN MID-CYCLE
Try placing something like a chair with books or heavy objects on it in front of the door. Tip it with objects under the front legs and place objects on its seat until the pressure closes the door and the dishwasher starts. Put additional objects on the seat to insure vibration doesn't make the door pop open. If the cycle completes, the problem is probably the door switch. If not, the problem may be with the timer switch. If it's the timer switch the dishwasher will probably stop at the same position each time.
Nov 30, 2007 | Dishwashers
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
