Question about Fujitsu Siemens AMILO D-7830 Notebook
How can i start reformatting my fujitsu siemens c1020 laptop?i had a cd for manageability of the laptop but i dont know what key is going to press when i open my laptop.
    Scholar:
  • 93 Answers
How to Format a Hard Drive in Windows XP
  1. Insert the Windows installation CD into the CD drive. Make sure that there are no other disks in the computer, and restart.
  2. At the "Welcome to Setup" screen, press either the "Enter/"F2"/"F1" keys to set up Windows.
  3. Press the C key to continue setup.
  4. Press the F8 key to agree to the license.
  5. Press the C key to create a partition.
  6. Enter the size of the partition, or just press the Enter key to use maximum size.
  7. Select the "New (Unformatted)" option, and press the Enter key.
  8. Select NTFS or FAT file system (select NTFS if you are unsure).
  9. Simply follow the prompts format the hard drive in Windows XP continue the Windows installation.
Posted on Dec 29, 2010
My son put a fujitsu siemens recovery disc into his emachines d620 laptop now when i log on it asks for a fujitsu siemens activation key which i dont have or want so i have to use laptop with reduced...
Do you have the eMachines recovery disc? If so, then you need to enter the bios of the laptop by pressing a speciffic key at the start of the boot process. It should tell you what key to press in the POST. Most likely across the bottom of the screen somewhere. The F2 and F10 keys are popular as well as the Delete key. Once you get into the BIOS, Locate the menu containing the boot sequence. Make sure to set the CD/DVD drive as the first boot device. Save the changes and exit the BIOS. Put the Recovery or Windows CD/DVD in the drive and follow the on-screen instructions.
Mar 17, 2011 | Computers & Internet
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
My laptop doesn't turn on and the red indicator of the battery
check the power settings and make sure that the battery and power cable settings are on when plugged in. Also sometimes a battery needs to be installed to do this. If the power adapter is working then all should be fine.
Aug 26, 2009 | Fujitsu Siemens LifeBook C1020 Notebook
My Fujitu Lifebook c1020 display is bad and needs swapping. I need a repair maual.
its pretty simple to change the screen on this computer, and you dont really need a service manual (i dont even think you will find one for that)
the way you do it is remove the rubber "dots" around the screen, there should be atleast 4.
when they are out, and you have removed the hidden screws, you can take of the frontbezel around the screen.
when the bezel is off you might need to loosen or remove 1 of the 2 screwes on each side at the bottom hinge.
the screen itself is fastened to the hinge with 2-4 screws on each side of the screen. remove them, take out the flat/wide cable on the backside, and disconnect it from the 5-6cm long printbord.
reverse the process when you put in the new screeen.
May 28, 2009 | Fujitsu Lifebook C1020 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Sound drivers
u can try this if u understand
http://support.fujitsu-siemens.com/Download/ShowDescription.asp?SoftwareGUID=CB518FBD-386C-4266-8730-432160E331E7
or if u have the drivers and utilities cd with u,u can install the drivers from that disk also,or check this out
http://www.helpdrivers.com/ingles/doc/instal.htm
try this out
Go here and enter your details...
http://www.fujitsu-siemens.com/support/linkapplication.html?LNG=EN&ID=263
Try Everest Home Edition (for free but you've got to Google for it)) and then to driverguide.com to pick it up, if the Fujitsu site doesn't help with it.
u need to install this driver for ur audio for the laptop
AC97 Compliant CODEC: Conexant Cx20468 driver:-)
Now try again here and click on c1020...
http://www.fujitsu-siemens.com/support/linkapplication.html?lng=en&id=263
and when u install the driver from griverguide.com follow this
After you installed the latest VIA AC'97 Enhanced Audio Controller driver from Driverguide.com , did you check the Device Manager?
What is seen in + Audio video and games Controllers?
Since you have tried to install other drivers, I am wondering if you could have corrupted the drivers.
If you have got the Right Drivers saved , I would suggest the following:
1. Start the Computer in Safe Mode
2. Open Device Manager> + Sound, video, and game controllers
3.Uninstall everything EXCEPT audio codecs, Legacy Audio Drivers and Video Codecs
4. Close Device Manager
5. Restart the Computer.
6. When the new hardware found message comes direct the wizard to the downloaded driver for installation
the audio controller is audio controller is a VIA VT8233 AC97 Audio Controller. VIA Technology website and download the VT8233 drive and it will definately work...good luck
Jan 27, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Laptop keys don't write
Can you try plugging in an external keyboard, just to see if that works?
Ron-
Feb 22, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu Siemens AMILO D-7830 Notebook Logo
299 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
