Question about SanDisk 2GB microSD Memory Card
My sandix 2gb microSD mameory card is write protected how will i remove it?
    Scholar:
  • 179 Answers
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Posted on Jan 18, 2011
Remove rewrite protection from card
SD and SDHC cards as well as microSD adapters have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 16, 2012 | SanDisk 2GB microSD Memory Card
Removing write-protection from SD card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 02, 2012 | SanDisk Microsd 2gb Memory Card Micro Sd 2...
Plz help me to remove write protection from my micro sd card.
Hi, slide up the Write protection switch which is white in color for the Memory Card Adapter to remove Write protection and Slide down to enable write protection of the Memory Card.
Please click on the link below to view the Write protection switch:
http://kb.sandisk.com/euf/assets/images/faqs/id1102_e3sdhc.gif
If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Apr 16, 2011 | SanDisk 2GB microSD Memory Card
Memory card was not formateing
YOUR MEMMORY CARD IS WRITE PROTECTED OR PASSWORD PROTECTED
REMOVE THIS PROTECTION
Nov 14, 2010 | SanDisk 2GB microSD Memory Card
My MicroSD card is write protected and i need to remove and add MP3s how do i undo write protection?
hello flip the switch for write protection picture here http://static.commentcamarche.net/en.kioskea.net/faq/images/0-hXBUyBSB-t555-1122-callout-s-.png
Nov 04, 2010 | PNY 2GB microSD Memory Card
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
My 2GB micro SD card not formatting he say remove your write protect but iam already do this
If it says write-protected, then... there is nothing you can do about it.
It's protected to not be formatted.
Aug 23, 2010 | SanDisk 2GB microSD Memory Card
How can i remove the write protect in my memory card if it doesnt have a slidable lock
The procedure for removing the right protection is given in the website given below.
please follow the directions and you can remove it.
http://www.troublefixers.com/remove-write-protection-on-usb-pen-drive-or-memory-card-or-ipod/
Thanx
Jul 20, 2010 | SanDisk 2GB microSD Memory Card
Write protection
There is a small switch on the card. The Sandisk site has a photo of a larger card, smaller cards like the microSD must be inserted into the standard SD adapter.
Jul 16, 2009 | SanDisk 2GB microSD Memory Card
Memory card write protect?
i had same problem..couldn't solve it with tape over the lock switch and many other ways.. so i purchased a usb card reader (about $5 max) and now it works fine!...just make sure the lock is off!
Jun 02, 2009 | SanDisk 1GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
136 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
