Question about HP DesignJet 1050c InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Posted on Feb 08, 2011
I keep getting System Error 0A0000 00000002
The error indicates low air pressure to the ink supply station. There is either a leak or the Air Pressure System (APS) is bad. Check for ink inside the rear door to the Ink Supply Station (ISS) and at the print head locations at the carriage.
If there is ink leaking at the ISS, replace the ink cartridge that is leaking. If there is a leak at the print head, replace the ink tube system. If there are no leaks, replace the APS. See the following link for parts: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Apr 14, 2010 | HP DesignJet 1050c InkJet Printer
Hp Deskjet 1050C Plus- Print head error
It is not unheard of to have a bad print head out of the box. I suggest you remove all the print heads and clean the ribbon connectors in the carriage that connect to the print heads. Clean the connectors on the print heads also.
If that does not clear up the problem, you may have a bad trailing cable (carries all the signals to and from the print heads) or a bad carriage.
Parts available at: http://www.lpscomputer.com/c-654-designjet-1050c-1055cm.aspx
Download Service Manual: www.lpscomputer.com/ec/manuals.htm
Jun 09, 2009 | HP DesignJet 1050c plus InkJet Printer
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
How do you resolve a hp designjet 1050C printhead path (1) - turn power off and check printhead path Type 1
May 20, 2009 | HP DesignJet 1050c InkJet Printer
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
Print head failures HP 1050c
the tube system has an air leak causing a dryfire situation. air + printheads = damaged printheads. most users replace the black printhead more often than the colors. the seal where the printhead feed pin fits into the carriage is the end of the tube system. the hole in the seal becomes to large and doesn't properly seal the air out. order the tube system. complete and concise instructions are included in the box for tube replacement. this is considered an end user replaceable part. good luck! please rate this!
Sep 23, 2008 | HP DesignJet 1050c plus InkJet Printer
Printhead replacement
I don't just change the printheads, go to utilities and recover printheads.
If all printheads are playing up, che3ck the magenta cleaner, if it's over full it can cause all printheads to fail, this info was taken from a page on the HP web page, but ?I can't remeber where.
May 13, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
1,104 people viewed this question
Seeker5211
Seeker5211
