Question about Garmin StreetPilot c340 GPS Receiver
How to replace internal battery
Internal battery dead...can it be replaced relatively easy?
  • Anonymous Oct 28, 2008
    GPS comes on when power button is pushed for about 30 seconds, and then shuts down.
This website sells a replacement battery and I am going to do it myself. I openned up the unit and it looks pretty easy as long as you are somewhat mechanically inclined and have a sodering tool. i'll let you know if it works out when I do it.
Posted on Jul 12, 2008
Black & Decker Cordless Hand Vac battery is dead and won't take charge, what do I do?
well obviously the battery needs replaced , now if it snaps on that makes it easy , but if its internal then its bit more trouble but not impossible , and you'll need to do a bit of research to see about costs of doing this vs' replacement of entire device, id start by looking up vac cleaner repair in your area , im sure they are a wealth of knowledge on this subject
Jan 12, 2017 | Decker Drills
When I put in new batteries in my easy share C1530 they immediately discharge
There is an internal fault that is shorting out the batteries get it looked at before batteries explode or burst and camera internals get damaged more
Dec 31, 2015 | Kodak Easyshare C1530 14 Mp Digital Camera...
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
When I turn on my latop shows two error messages 0250; System battery is dead, 0270, real time error. and does not raise the operating system.
Hello and welcome to FixYa.Com
The 0250 error indicates your CMOS battery is dead and needs to be replaced. This is a common issue on machines once they get a few years old.
The 0270 error indicates your main board is not getting the date and time from your BIOS. This is more than likely directly related to the 0250 error.
You have 2 choices: 1. Replace the battery yourself. - Not so easy but not very expensive. 2. Take it to a professional repair location and have them do it. - Easy but expensive.
If you go option 1 then he following website contains very detailed instructions on replacing the CMOS battery in a R31.
If you go option 2 then the cost should run you anywhere from $25 - $100 depending on their labor rate. Always get an estimate first and make sure they understand exactly what you want done.
I hope this helps, and dont forget to vote!
Feb 28, 2011 | IBM ThinkPad R31 2656 Notebook
My internal backup battery is dead, can anyone tell me where to find the specs to replace the internal battery? and what type of internal battery is it? Thanks
If it's been a few months since you have used the camera it's normal to be dead.
Charge the camera and use it and the clock battery should come to life.
The camera will work fine even if the battery does not work, however, you will not be able to record time and date.
Feb 16, 2011 | Sony DCR-PC350E Mini DV Digital Camcorder
Brand new battery keeps running down. I'll jump it off, and two days later, battery is dead. Today, the A/C went out. Are these problems connected? What's running my battery down? Is It a belt issue?
It's probably your alternator. When your alternator isn't working properly your battery provides all or most of the car's electrical power. Until you can replace the alternator you can disconnect one of your battery cables while the car is not in use and that will prevent the battery running down. One way to check if your alternator is the problem is to disconnect the negative battery cable while the car is running. If the car goes dead, it is very likely an alternator problem. It usually requires about an hour of labor to replace an alternator. Most alternators can be rebuilt at an alternator repair shop and that is cheaper than buying a new or re-manufactured one.
Oct 31, 2010 | 1998 Ford Taurus
How to access the battery on an iphone?
iPhone has an internal rechargeable battery. The iPhone battery isn't user replaceable; it can
only be replaced by an authorized service provider. For more information, go to
Oct 04, 2010 | Apple iPhone (16 GB) Smartphone
Battery went dead. replaced battery and now it
Last night I replaced my battery and my unit would not go any further than the Pearl logo. So this morning I downloaded the firmware upgrade from, and followed all the troubleshooting instructions that popup when you start the program:
start the program,
remove the battery,
hold the play button while plugging into usb,
release the play button the the term "initalizing" replaces "searching",
check the box that says "format data",
click the start button to replace the firmware.
After I did this, my pearl started normally, and my computer recognized it again. It also fixed my aac-error problem.
Jul 16, 2009 | RCA TH1602 MP3 Player
Minolta 7000 internal battery
I would recommend haveing it checked by a camera repair company or a local tech if you know one.
Il look into this though will get back to you.
Jul 22, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Black 2gb ipod nano
The most likely cause of this problem is a dead battery.
Most Apple stores will tell you it's more cost effective to replace your iPod rather than repair it but, the battery can be changed and parts are relatively easy to get hold of on eBay for around about £10.
Mar 06, 2008 | Apple iPod nano
Garmin StreetPilot c340 GPS Receiver Logo
508 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
