Question about Lexmark C762 Laser Printer
Lexmark c762 problem, the display has all diamond shape and the only way it reset is by un pluging from rear of printer, but 3 hours later while not in use the same thing happen again.
  • apsprinters Dec 29, 2010
    need more help
  • apsprinters Dec 30, 2010
    the solution seems to have taken care of this problem
  • 3,530 Answers
Welcome to Fixya
Since the problem re-occur after 3 hours. You might need to restore the printer back to factory state just to make sure that this is not a firmware issue. Here's the procedure on how to restore the printer to factory settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 When Restore appears, press Select. The message Restoring Factory Defaults appears,
followed by the Ready message.
When you select Restore:
- No other button actions are available on the operator panel while Restoring Factory
Defaults appears.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are
deleted. (Resources residing in flash memory or on the optional hard disk are unaffected.)
- All menu settings are returned to the factory default values, except:
• The operator panel Display Language setting in the Setup Menu.
• All settings in the Parallel Menu, Serial Menu, Network Menu, and USB Menu.
Thank you for using Fixya!
Posted on Dec 29, 2010
  • 1,110 Answers
The printer is failing it's self test function. If there are no failure codes displayed then the only remedy is either to perform the reset procedure or to call your local service center for service. Here is the text from the Lexmark Manual and the reset procedure:
The operator panel
display is blank or
displays only
diamonds.
The printer self test
failed.
Turn the printer off, wait about 10 seconds, and turn the
printer back on.
Performing Self Test appears on the display. When the
test is completed, the Ready message is displayed.
If the messages do not appear, turn the printer off and call for
service.
  • Edwin Martens
    Edwin Martens Dec 30, 2010
    Are you getting any error codes? Or is it just the diamonds?
Lexmark C762 Color laser printer will not boot up, it is plugged directly into a 110 outlet, the cables are seated well, the USB cable is connected to the printer,
If it seems to power on but you don't get anything on display.....you're LVPS (Low Voltage Power Supply) is shot. Needs to be replaced but Lexmark no longer support this model. You might be able to find one from third party parts site.
Nov 17, 2016 | Lexmark C762 Laser Printer
How to replace panel opreator lexmark c762
Please see the attach image for the instructions on how to remove and replace the operator panel of the Lexmark X762.11_7_2012_9_33_23_pm.jpg
Nov 07, 2012 | Lexmark C762 Laser Printer
How do we clean the rollers?
Please do refer to this link: http://bit.ly/OqwM6c to clean the transfer units. Should you require further assistance, please do not hesitate to contact us on LxkListens@Lexmark.com.
Jul 17, 2012 | Lexmark C762 Laser Printer
Lexmark C762 not printing any color but black
Here's an article in the Lexmark website on All Color Planes Missing Except Black. Just click on this link: http://bit.ly/9JRRD2. Follow the instructions carefully. If all else fails, I strongly suggest you contact Lexmark Technical Support to further investigate the problem.
Jul 01, 2010 | Lexmark C762 Laser Printer
How to fix 108 service printhead error on c762 lexmark printer
Hello, Please try this: Power off the printer, take the Color cartridge out(Magenta), take a thin and dust-free cloth or tissue and clean the hysinc mirror and the printerhead lens. The hysinc mirror and printerhead lens is in the printer not on the magenta cartridge. Reinstall the print cartridge and power on. Try again to print this will help.
Mar 19, 2010 | Lexmark C762 Laser Printer
Lexmark LP4037 5E-ERROR CODE 923,WHERE CAN I FIND FUSER OR HOW CAN I REMOVE THE ERROR
1. Enter the Configuration Menu by holding down the SELECT and RETURN buttons while powering on the printer until the display reads PERFORMING SELF TEST. After the self test, the display will read CONFIG MENU
2. Select individual reset for fuser or ITU kit
Jan 31, 2010 | Lexmark C762 Laser Printer
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
83 itu maintanece
You replace the ITU it has reached its end of life cycle.
Jan 22, 2009 | Lexmark C762 Laser Printer
I have printer x3480 when attaced to power it will not work just, can not shut off with out un pluging from power. Readout just prints COVER OPEN ?
Try to reset your printer to factory settings (Go to menu)
Check connections and cables
Check Power supply
You can find further help downloading your manual or getting support from here:
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569478_0_en,00.html
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 15, 2008 | Lexmark Office Equipment & Supplies
Lexmark C762 Laser Printer Logo
335 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
