Question about Kwikset Professional Door Lock installation Kit
Thank you for taking time to read this. Hopefully you can answer my question. I have no problem with keying...My question is~How do you make 'Master Locks'? Having one 'Master Key' that opens all the locks, but yet still be individuals locks. The kit has 'Master Pins'. If you could get me started, I'm sure I could figure it out. Thank You Again. Hope to hear from you.~The Key Man
    Problem Solver:
  • 13 Answers
The art of Master Keying is far too complex to post as an answer in here. I assume you have experience with re pinning locks. There are HUNDREDS of books available on the subject, although where you buy it from may require you to provide a locksmith license in order to buy.
Posted on Jan 23, 2011
Need PDC diagram with labels 2000 Jeep Cherokee XJ 4.0 IL6
posted here 100 time.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
WJ.
all cars have spare conn,. and fuses. for options not opted.
they do not make a harness for all 100 permutations of options
that would be crazy.
no its not SAFE
pull the neg, lug on battery before any PDC work.
or take the risk of eating acid or far worse. "BOOM"
if you work on a car, the FSM is the bet book.
its all there, just read it.
Feb 22, 2014 | 2000 Jeep Cherokee
Fuse short
You may want to check out your regulator. It "cleans" the power coming from the stator. You may be blowing those fuses because of that.
Jul 04, 2012 | Ducati Motorcycles
What are the OBD codes for 1994 Jeep Grand Cherokee 4.0
OBD Codes can be read turn therre times ON/OFF ignition key (without start engine)... read light sequence and note... Read the Check Engine Codes
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 19, 2011 | 1994 Jeep Grand Cherokee
02 Hyundai Accent. With ignition turned on the key warning light on the dash if it flashes 5 times then go,s out car wont start, if it stays illuminated when ignition is turned on car will start. Can you...
you can reprogramme this key yourself i think but iam not sure of the sequence ,i think you turn key to acc position 5 time whilst holding the brake pedal down reading the alldata bible it says only programable with diagnostic but it can be done with master key but i have roberto the hyandai man reprogramme keys at the airport parking when the original keys have been lost and a spare cure from the door lock barrel but he wouldnt show me but i am sure he never had a master key and the brake lights were on all the time he was doing it ,as i watched out the corner of my eye pretending to be taking a door lock out for him .
Jan 25, 2011 | 2001 Hyundai Accent
I have a confirmation number which is 87543784 and the wii told me i need a master key
Hi Gillesalakl
Please everyone that comes across my info take a few seconds of your time to rate my solution which you can select at the bottom of my answer Was this solution helpful? YES or NO :)... As i have taken time to answer your question the best i can Thank You......
Default pin code is 0000 thats if you have never picked a code before..Otherwise if you have and forgotten it you can go to this link and reset it cheers nikki
http://wii.marcansoft.com/parental.wsgi
Jan 08, 2011 | Nintendo Wii Console
Master Mechanic garage door opener has lost it's range. Only works when remote is very close to garage door. I have replaced the batteries in the remotes, reprogrammed the remotes and disconnected the...
Sorry to read about your problem, I hope this helps you out.
either 2 things, you have a defective receiver, or their is a outside interference jamming the signal. this is a common problem, in some areas.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kitchen Ranges
Hi i am having trouble with my wii. i have forgotten my 4 digit code and it says to call the consumer service number listed on my Wii operations manual and provide the confirmation code it gave me. it said...
Hi donnasrocks
Dec 27, 2010 | Video Game Consoles & Games
CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
Apr 15, 2009 | Panasonic KX-T7636W Corded Phone
New car key cut from master ... how do i make it work?
yes you need to take it the the nearest hyundai dealership and have the key reprogrammed.. this will cost you about $45.. good luck keith...
Mar 20, 2009 | 2000 Hyundai Accent
L6 MOTOROLA
power on the phone , press the menu key in the middle of the keypad , scroll down to initial setup then scroll down and select the master reset then enter the default code 000000 hopefully you have not changed it if you have then enter the code you changed it to.
Mar 20, 2008 | Motorola Mobility L6 Cellular Phone
Kwikset Professional Door Lock installation Kit Logo
83 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
