Question about Cell Phones
I was charging my Samsung S8003 with USB charger and I noticed it could not turn on again, I tried charging it several times but it does not charge also. What could be wrong? Adebayo
3 Suggested Answers
SOURCE: Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Posted on May 25, 2010
SOURCE: my samsung gravity 3 won'ty charge in car
This problem cannot be fixed. You'd have to return your Gravity 3 and exchange it for another model. It's a known problem with Samsung and should acknowledge it and recall this product (or fix it with a software update free of charge). I spent a whole day at different T-Mobile stores and finally a rep showed me the technical bulletin on it and exchanged the phone.
Posted on Sep 14, 2010
Why wont my Samsung Galaxy Tab on 3 Mobile Tablet PC charge
either your battery is shot as in dead or your charger is faulty
you could try to charge it using a usb lead in your computer or another usb port to see if that works , or try another charger to eliminate your lead /charger you are using
Aug 01, 2014 | Samsung Galaxy Tab on 3 Mobile Tablet PC
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
Why my samsung galaxy note 2 will not turn on and it is completely charged
To power on, Take your charger and charge your phone. When it shows that it charges (when the indicator is moving) quickly take out your charger and immediately take out your battery and put it back in again and it will turn on.
Jul 01, 2014 | Sony Cyber-Shot DSC-P31 Digital Camera
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Tablet wont charge
Apr 01, 2014 | Samsung Tablets & eReaders
Samsung galaxy Y pink wont charge
i tHink iNnn yOur cEll pHone cHarging piNn iZzz dEstroyed !!....!! rEpair yOur cEll pHone tHen iTz wOrking !!....!!
Apr 07, 2013 | Samsung Galaxy Y Gt-s5360 Pink Factory...
My Samsung Captivate won't take a charge. It works on the both house and car charger but as soon as I take it off the charger it shows zero charge left and quickly shuts down. When I leave it on the...
I want to let you know that the battery of your phone is bad.
Please, replace it with a new battery.
Please, when you want to buy your battery, make sure you buy it from samsung shop because there are many shops selling fake batteries.
Thank you and God bless you for contacting FIXYA.
Sep 02, 2011 | Samsung Captivate Cell Phone
Samsung S8003 Jet battery life problem
try to do these steps for your battery. 1.  switch off your phone 2.  check if the battery is loose or not properly fitted up.. >> insert a clean soft cloth at the back of your battery to make it more in tack or to fit more and observe. 3.  try borrowing the same fully charged battery from a friend and observe it.  >>if the battery gives you the same issue, you would want to give it a try at samsung service centers.  4.  ask the help of a friend who knows how to take a reading from your charger.  >>this will help you to know that your charger is giving the much needed voltage rating for your phone during charging.  >>you would also want to consider borrowing a charger from a friend and observe.  5.  consider bringing a additional fully charged battery while you are on the move or during your business trips.
for your notes, 1.  notes are really 100 characters, i am afraid,there is no possibility as of this moment to increase that.
Mar 07, 2010 | Cell Phones
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
