Question about iPhone Apps
I have a hp photosmart c4700. a the paper feed sensor has been damaged where can i find one to replace the old sensor? please
  • 2072 Answers
SOURCE: ADF Won't Feed the Paper
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Posted on Jan 25, 2008
Buschchris1
  • 474 Answers
SOURCE: HP Photosmart 3310 does not recognize paper in tray
This is usually do to a sensor, your correct on that, thers usually a plastic piece that indicates theres paper and its broken or worn.
The other thing is that it may be the little rubber grabber is worn and not grabbing the paper, so the printer thinks thers no paper because nothings going through. These parts can be orderd but are usually costly depending on the printer. If its under warranty, take it back.
Also, check the trey and make sure it isnt a I.D.10.T error and you just set the paper to legal or something. I've made that mistake before.
Posted on Feb 16, 2008
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 55 Answers
SOURCE: Problem installing HP photosmart C4700 series
Try posting a question. Others will then be able to help you with solving your problem.
Posted on Mar 10, 2010
vinay229229
  • 1121 Answers
SOURCE: Hp photosmart c3180 will not feed paper to print
Might be paper pick up roller warn out, clean or replace it.. For tech guys only: check for separation pad acting while service station performing? if not remove service station check separation pad leaver notch not in proper position in service station, position it. remove total mechanism up to pick up assm.. check pick up roller spring.. tension the spring. fix it back.. verify the print ...
Posted on Jan 09, 2012
NVM reset for hp photosmart c4780
You can gain access to the service menu...refer to Cartridge Error Clear bypass procedure below (as guidance of how to get in):
For any severe cartridge error related message, on the HP C4600, C4700 or D110a printer models, I suggest you run the internal Tap 41 diagnostics test which will tell you the electrical health of the ink cartridge - in many cases the cartridge is internally electrically damaged and will need to be replaced. In addition, you can temporarily bypass an 'incompatible cartridge(s) or Missing/Not Detected error message by performing the Cartridge Error Bypass procedure...refer to two Youtube videos on how to do this:
HP Photosmart C4600 & C4700 Printers - Tap 41 Diagnostic Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
Low Ink Warning and Other (i.e Incompatible Cartridge) Errors, HP 60 & HP 61 Ink Cartridges:
http://www.youtube.com/watch?v=5_suW3U6e08
Feb 28, 2013 | Cisco Photosmart C4780 Wireless AllInOne...
My hp photosmart C4700 singals out of paper when the paper tray is full
Check the paper tray for a bent or broken sensor switch. E-mail manufacture or call on phone to have them walk you thru this.
Nov 26, 2010 | Computers & Internet
C4780 printer cartridge problem cannot fix problem is this same as ink cartridge problem what do i do tried cleaning ink cartridges but still says samething on display it happend in middle of printing...
Ok. As per your statement , the power cable is working properly. So , the problem is with your printer only. If you are using the original cartridges and still having the priblem , it is only the defualt printer. If you are having the extended warnty for (3) years , you are adviced to contact ' HP Authorised Service Partner'. they will replace your old printer with new one. Generally the HP company is giving 1 OR 2 years warranty for replacement.If have paid extra amount for extended warranty , your printer may have warranty up to (3) years. So, within the period of (3), the HP Authorised Service Center will replace your printer. They will give reciept for your old printer, and replace your prionter within a (15) days to (25) days with new one. If the printer is not having warranty or extended warranty , the printer is assumed to be as damaged. So, you have to purchage the new one. Be, cuacious the HP printers are not repairable. Please don't try to approach the local repairer.They will eat your money and also don't try to purchase very very very costly HP in cartridges. I think your problem may be solved.
Oct 03, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
My HP Photosmart C4700 keeps saying the printer cartridge is in wrong. I have taken them both out and put them in and they are correct.
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Sep 20, 2010 | HP PS C4780 All in One InkJet Printer
Hp Photosmart C4780 won't recognize new ink cartridges
Switch off the printer and switch on again,Unclip the cartridges one by one and clip back in again this sometimes cleans out the connector pins.This has happened to me.
Sep 02, 2010 | Cisco Photosmart C4780 Wireless AllInOne...
The back of our hp photosmart c4700 fell out. It appears to be part of the paper tray. we could use a diagram to help us put it back in. we are not "techies".
Take a look at this video on how to open and close the back panel door...
Hp Photosmart C4700 tutorial
Open the link and watch the video (step two), I hope this will definitely help you..
Good luck.
Thanks for using FixYa.
Jun 23, 2010 | Office Equipment & Supplies
The printer keeps messaging ink on sseveral colours is low but it is not. Have even tried new cartridges but no difference, same message . Seems to be misreading ink level
Some printers need special software (that shipped with the printer) to "tell" the printer that the ink-cartridge has been replaced, and that the ink-levels need to be fully "reset".
Apr 23, 2010 | Computers & Internet
What is a incompatible print cartridge? Its coming up with a warning exclamation mark and it wont print?
What is a incompatible print cartridge? The printer "Thinks" that the print cartridge, is NOT an original HP PhotoSmart one. Even print cartridge have chips.
Mar 28, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
Paper will not feed
It is a problem with printer paper sensor pls clean the printer paper sensor. if problem does not solve then you can checked it from service center.
Oct 20, 2009 | HP Photosmart 2575 All-In-One InkJet...
Usually if you leave the printer off for sometime the ink get dry on the heads or some ink may leake to the sensores so take the cartrage out clean it and clean the heads with cotton swaps...see if the help and let me know
Sep 13, 2009 | Office Equipment & Supplies
iPhone Apps Logo
Top Apps Experts
Bill Boyd
ray gallant
Are you an App Expert? Answer questions, earn points and help others
