Question about Playmobil 4320 Rc Module Set
We have a rc-modul playmobil 4856 and the connections are made, car and remote both have new batteries, but it just doesn't work.
2 Suggested Answers
rac7529
SOURCE: Playmobil RC Train set 4018 - have replaced all
Clean the terminals in the remote and at the end of the battery,also inside the battery compartments that holds the battery in the charger and the the train itself. i hadn't used ours for 10 years and hadn't realised that we had left the battery in the train and the 9v battery in the handset. Tried charging it and nothing, but once i had cleaned all terminals of the green residue that had built up, it charged fine and the train ran for 45 mins before needing a recharge.
Posted on Dec 12, 2012
Remote not working throttle or steering ,and remote keeps saying low battery but has brand new batteries
FAQ - Answers for Common Redcat RC Questions
www.redcatracing.com/FAQ
Q. I installed batteries in my car and in the remote control but when I turn on the power ... You may have some things such as throttle working but no steering. ... If it doesn"t your cord may have come off track and you can simply open the rear of ...
Why is my remote control not working? - Geardup RC Ford ...
https://www.ifixit.com/.../Why+is+my+remote+control+not+workin...
iFixitFeb 19, 2015 - To fix this, you can replace the batteries. ... The GEAR'D UP RC Ford Mustang GT is a remote controlled car released ... Is this a good question?
Troubleshooting an RC That Won't Run - Radio Controlled ...rcvehicles.about.com > ... > Troubleshooting, Repair, and MaintenanceRadio Controlled Vehicles Expert. Share ... The batteries are often at the root of manyRC problems. ... Loose or broken wires can result in a host of problems.Radio Control FAQ ' RC Toys ' New Bright
Dec 25, 2015 | Exceed-RC RC Truck
Rc-9 remote only works if within 2 feet of bose lifestyle 12
Replace its infrared emission LED. It is weak, and so the signal out from the remote control too.
Nov 18, 2012 | Bose RC-18S Remote Control
New Bright, F-150, Red Thunder 4X4: Truck goes into "static" mode when forward or reverse is pushed on remote. In other words, truck starts up when turned on, steering, horn and lock work fine,...
Get new battery, I have 4 batteries, all will turn it on, get horn lights, sound. 2 do the exact same thing yours is doing, 1 runs about 5 min then starts into your problem, 1 is good and will run for about 20 mins.
Aug 27, 2011 | New Bright Ford F150 Rc
Does the playmobil fire engine model 4821 make a noise or is it just flashing lights? If I brought the remote control model 4320 would this make the fire engine noises?
According to the details on their website, the 4821 only features flashing lights, no sound effects. The RC 4320 doesn't look like it has buttons for sound effects either, only controls for driving.
Mar 02, 2011 | Playmobil 4821 Fire Engine Truck
My rc car stopped working after 3 mins of play time. i put new batteries in and still not working. my son got it for christmas. there is a paper that says if u have problems go to support@toys 1628.com but...
My son receive a Christmas present a remote control car and it doesn\'t turn....... I emailed the support@toys1628.com 12 days ago and they have not responded...... this is a crappy way to do business
Dec 24, 2010 | Parents My First Rc Car
Playmobil RC Train set 4018 - have replaced all batteries but the charger wont work. It won't power the train - remote working fine. Don't know what else to do.
Oct 29, 2010 | Playmobil Train Station
Playmobil 4396 battery charger available
I would like to buy it - how do I contact you? Should I leave my email address here? --Paul
Jun 06, 2010 | Playmobil Rc Train With Light
I have an older Carrier Heat Pump which I am trying to update the thermostat control with a Hunter model 44550. The problem is that the wiring to the current thermostat is as follows, G= green wire, R=...
JUMPER STAYS BETWEEN RC AND RH SO YOU HAVE INCOMING POWER FOR BOTH COOLING AND HEATING. THE WHITE WIRE YOU SAID C IS COMMON AND SHOULD BE USED IF POSSIBLE TO COMMON TERMINAL ON NEW STAT . IF THERE IS NO COMMON, THEN CAP IT BUT YOU'LL BE CHANGING BATTERIES EVERY FEW YEARS. I LIKE THE STATS WITH A COMMON POWERED OFF THE TRANSFORMER BUT YOURS MAY NOT HAVE A COMMON. THE GREY WIRE CONNECTED TO THE E TERMINAL IS FOR EMERGENCY HEAT. IT KILLS POWER TO THE HEAT PUMP, HEATS THE HOUSE ON IMMEDIATE CALL FOR HEAT WITH JUST THE INDOOR BLOWER AND THE INDOOR HEAT STRIPS. THIS PREVENTS ANY DAMAGE OR INCREASED DAMAGE TO THE COMPRESSOR IF YOU SUSPECT A PROBLEM.YOU SHOULD HAVE A TERMINAL ON THE NEW STAT THAT IS MARKED E OR PERHAPS X2 OR W3. THAT IS WHERE THE GEY WIRE GOES. IT IS POSSIBLE THE WIRE CONNECTED TO W DOES THE SAME THING AND YOU CAN GET BY WITHOUT THE GREY WIRE CONNECTED.ALSO SELECT SINGLE STAGE HEAT PUMP. SINGLE STAGE COOLING AND TWO STAGE HEAT . FIRST STAGE HEAT IS YOUR HEAT PUMP AND SECOND STAGE IS YOU STRIPS.
Oct 26, 2008 | Carrier Heating & Cooling
Playmobil 4320 Rc Module Set Logo
632 people viewed this question
Top Playmobil Toys Experts
thegtw
Tom Chichester
Are you a Playmobil Toy Expert? Answer questions, earn points and help others
