Question about Philips Audio Players & Recorders
I need a new drive belt for a Philips FP320 Turntable
  • 153 Answers
SOURCE: I need a drive belt for my CP 1100A turntable!
Measure the length, width, and thickness. Go to www.mcmelectronics.com and find the belt that is closest.
Posted on Apr 21, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Belt broken; how do I fit in a new one?
I believe the platter simply lifts straight up off the spindle. Put the new belt on the platter and reinstall it. Then, working through the access hole in the platter, put the belt around the motor drive shaft. Rotate the platter a couple of revolutions to make sure everything's seated properly and you should be back to spinnin' the hits in no time!
Posted on May 04, 2009
Grubhead
  • 5126 Answers
SOURCE: Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Posted on Jan 26, 2010
  • 7 Answers
SOURCE: Kenwood Trio Turntable belt broken.
I have them listed as item 250423608612 on Ebay .. softwaredivision
Posted on Feb 12, 2010
  • 256 Answers
SOURCE: model PS-LX300USB Turntable Drive Belt
Hi Norman
Normally the belt does not go through any special tensioners or anything of that nature,The belt should go directly from the spindle motor onto the inside of the platter. Hook the belt on the motor section and lay the belt open wide inside the turntable. Next, replace the platter and manouvre the belt onto the platterinside through the two large holes
Posted on Jun 08, 2010
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Turntable running faster after changing the belts
    I have found a link to give more information on speed control and new belts
    May 07, 2014 | Philips 100 ft. 16 ga. Speaker Wire -...
    Prolectrix usb turntable
    Getting drive belts is easy, fitting them is the problem. If it is still attached in any way make a note or a photo of how it is fixed. This will help to putting a new one on. Measure the diameter of the old belt in mm. You will also need to measure the thickness in mm too. Then put these words into Google: "Turntable Belt xx mm" (use the diameter measurement in place of the XX). Then search the results looking for something that is very close to your belt. If you find the belt, try searching again for the fitting of it. Quote the model number of the turntable. The fitting instructions might even be found on this site.
    Feb 27, 2014 | Audio Players & Recorders
    My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
    Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
    Jan 01, 2013 | Fanimation FP320OB The Islander® FP320...
    I need a replacement belt for a philips 685 electronic control turntable. unit # 22AF685/44
    Dear bunnetta,
    the belt for your turntable can be ordered from here:
    http://www.lptunes.com/Philips-AF685-turntable-belt-p/phlaf685.htm
    Regards
    Oct 21, 2010 | Philips Audio Players & Recorders
    Turntable will not hold pitch,speeds up or slows down.
    try replacing the drive belt with brand new one and see if this improves the situation
    May 27, 2009 | Philips gemini XL-500 II Turntable
    Belt drive replacement B&O Beogram 1000, type 5203 turntable
    length approx 30mm shorter than old one, knock out pin on shaft to take platter off.more often than not the motor runs slow after repair,if its a round style ac motor htey cant be fixed.
    May 09, 2009 | Philips gemini TT-02 MK2 Turntable
    knock pin out.make sure idler assy moves freely away from motor shaft.
    NAD 533 Turntable
    Just do a search in Google for "NAD 533 Drive Belt"
    - OPTiC
    Turntable Technician
    www.1200s.com
    Sep 01, 2008 | NAD 533 Turntable
    Started playing too fast, now won't turn
    Check that the belt has not perished.
    Oct 06, 2007 | Philips WMM142211 Turntable
    198 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
