Am getting FP error message on a Whirlpool 6th Sense washing machine. Have removed foreign objects from filter but still getting error message. What more can i do?
  • 1,557 Answers
Your right the error code is filer pump now disconnect power and let unit sit for 1 hr should reset its computer
dam computers
Posted on Dec 29, 2010
I got the same error some day. It was written FP on the little screen and a red led was lit, i simply plugged out the plug for 10 seconds then plugged back in and pressed the the button to start and resumed cycle time which remained
Posted on Aug 03, 2012
Display is showing FP - any ideas what I need to do?
FP message (on a Whirlpool Washing Machine or derivative of it) usually means that there is a 'F'ilter issue: check your machine drain pipe and drain filter and remove any obstructions from 'stuck' objects such as socks, hanky, coins, etc ...
Sep 23, 2011 | Washing Machines
I'm getting an F02 error on my Whirlpool front loading washing machine. How do I fix?
The F02 error code is for a long drain. (See image below).
Without a model number I am only able to provide you with generic instructions. I have included a set of illustrated instructions you will need to check drain pump filter. (See images below). Once the bottom panel is removed the drain pump filter cover looks like a gas cap. Remove that and then remove any foreign objects. If the drain pump is clear it probably needs to be replaced.
Jan 12, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6th Sense displaying FP and clean pump is lit ! How do you clean pump ?
On the lower front panel is a small door which may be behind the kick panel. Behind this door is the drain filter.. Do not undo this filter till you have emptied the machine, as any water in the machine will flow from the pump, when opened.. Leaning the machine back against the wall will help contain what water is left in the machine..
Undo filter, check and clean.
Check that a coin or hairclip has not fouled pump impellers.
If the impeller has come away from the pump shaft, the pump motor needs to be replaced.. A tech should be called for this job!
Good luck....Nomess
Aug 04, 2010 | Washing Machines
FP fault code on whirlpool washing machine
i have a whirlpool 6th sense awo 10761 and evrytime i start a cycle it stops and the door lock light flashes can any one help me
Nov 07, 2009 | Whirlpool Washing Machines
My whirlpool washing machine won't spin. In the digital display it is saying FP
Hi
Remove pump and check the pump for any foreign objects which is stopping the impellor from turning.
hope this will help.
Thanks for contacting fixya.com
Oct 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump light keeps coming on
That is the way to fix the issue. remove the debris and hope nothing else gets caught in the trap
Jan 19, 2009 | Whirlpool AWM8163 Front Load Washer
FP code appearing on lcd disply
remove pump and check pump for foreign objects stopping impellor turning, worked for me hope this helps
Dec 26, 2008 | Whirlpool AWM8143 Front Load Washer
Whirlpool 6th sense awm8163 programes never stops now cannot get it to work at all
The pump is at the lower left of the front of the machine covered by a white plate. Use a bowl to catch any remaining water when opening the screw thread inside and then clean and replace. If it is truely beyond repair then a new filter pump can be bought from ebay for £3 or thereabouts.
I have just drained mine manually in this way and am going to run it empty with soda crystals to glean a few more days use whilst the new pump arrives.
Good luck :)
Jan 20, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
1,567 people viewed this question
Top Washing Machines Experts
