Question about Samsung SGH-i450 Cellular Phone
My slider is not working properly - Samsung SGH-i450 Cellular Phone
  • 384 Answers
It may be there are some dust particles in the sliding just wash it .
Posted on Dec 29, 2010
When charging DS lite the light stays orange
The issue is not with the fuses or with the battery. That end is working properly if the light stays a constant orange. The issue is with the other end, how the system powers on. Check the power slider (on mother board) or the L2 inductor (located below the slider). Chances are the tab on the slider has broken off or the L2 slider broke off from the motherboard.
Jul 06, 2013 | Nintendo DS Lite Console
Everything lights up but the screen is black and stays black
hi Friend your Problem is that your cellphone is not working properly all the functions are working but screen stays black.so it can be happend by 2 reasons.-1>i think you are using slider phone,so slider phones always uses a belt between screen and keypad some times, i think in your cellphone its not working properly you'll have to go any repairing shop and fix this problem with changing your belt..2>if you are not using slider phone then something wrong with your display ,means you'll have to change your display.
thnks , for further query feel free to ask ,i am always here for you.
Aug 14, 2011 | Cell Phones
I can't get the yellow wire of the dimmer slider to work properly using a conventional 3way switch on the other side. I do have the slider on the load box. Could it be that i need a Lightolier ZPR-3 on the...
Most of this style lightolier product requires the proper remote such as the zpr3. Leviton illumitech is a similar design, but uses regular 3 way wiring.
There are others out there as well, that do not require the remote.
Mar 05, 2011 | Lightolier 600Watt Preset Slide Dimmer
Slider part keypad not working properly, only number keypads are working
Possible that the flexible membrane strip of the connection to the slider keypad is broken off there by cutting off the connection.
These membrane strip wires must be procured to be installed back into the main board and connected to the slider pad.
Attempt only if you are experienced to do these delicate jobs.
Oct 23, 2010 | Cell Phones
There is a squeaking sound on the front right wheel of my L300 van and its getting hot even on a short drive!
On older vehicles rust can be a major factor in how your brakes work. You probably have a problem with the calipers not floating properly because the brake pads are jammed in place by rust. You will probably need to purchase new brake pads, discs and possibly new brake sliders . Take the calipers off , knock out the brake pads, and carefully take of the shiny brake sliders. The rust is under the sliders. Two bolts hold the caliper mount on , it will be easier to work on if you remove it from the vehicle. Take a file and clean the rust off the iron caliper mount till there is only metal. Coat the filed surfaces on the caliper mount with anti seize and put the sliders and the pads back on. Make sure the new pads float properly (not jammed like before) and reassemble. I have had several old Mitsubishi's with rust on the caliper mount that did the same thing. Wear a mask, it is a dirty job but filing off the rust should fix the problem.
Aug 26, 2010 | 1990 Mitsubishi Minivan
The keys on the slider don't work properly. I press them but nothing happens. So the arrow keys and two side buttons (call and hangup) don't work. Also, when I slide the phone shut, the white lights on the...
it is the slider problem which is called ribben problem. u 600 phone is so thinn and samsung they putted so thinn ribben in that it goas damage so quickly. try to change slider or ribben.
Dec 30, 2009 | Samsung SGH-U600 Cellular Phone
Samsung Gravity T459 phone. Slider spring popped out of position, how do I get it back into proper location?
Nov 24, 2009 | Samsung Gravity SGH-T459 Cell Phone
Iphohe dropped in clean water. Slide will not
inspect this mechanical slider for proper seating.... it may be slightly ascew in the grooves .....also look to see it the nub button it acuates is popped past the slider push it down and slide the slider past it to reseat
Nov 22, 2009 | Apple iPhone Smartphone
SGH G 600
is strip problem ok plz change rs200 only any more info sent me mail okkkkkkkk
Aug 29, 2009 | Samsung SGH-G600 Cellular Phone
Samsung SGH-i450 Cellular Phone Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
