Question about BenQ FP731 17" LCD Monitor
I have a Benq Q9C4 monitor and when I press the power button on the front, it lights for a second and then goes out. Nothing shows on the screen, (It remains black), and no heat comes from the vents, so obviously nothing is working internally that creates heat. Do you have any ideas?
SOURCE: Q7T4 monitor
I have the same trouble,with the Benq Q7t4 power, but can you tell me how I can get it apart, I have taken all the screws out but can't seem to dismantle it.
many thks colin
Posted on Jun 30, 2008
  • 5 Answers
SOURCE: BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Posted on Jul 19, 2008
SOURCE: BenQ FP731 17" LCD Monitor Problem
Had the compete dark screen problem. Green/amber power light was coming on and off as expected but no image would appear on the screen.
Found PF751 to be open.
Thnaks for the help people.
Posted on Oct 08, 2008
freetek
  • 5568 Answers
SOURCE: BenQ FP91G+ 19" LCD Monitor black screen
Possibly either the backlight lamp or its associated power supply has failed. Power buttons (mostly LEDs) have constant availability of low voltage (for some other circuits too) otherwise they wouldn't 'wake up' on command from a computer as some do.
The blackout could also be due to a failed main power supply so the incoming video is no longer being processed.
Posted on Nov 01, 2008
SOURCE: Benq FP71G monitor screen displays momentarity on
check your power supply and power cable and check your monitor cable if its not damaged..or try your monitor to another computer..
Posted on Jan 19, 2010
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Contrast decreases to Zero
Had the same problem recently with a Benq FP71G+. It was still under warranty so I called customer care and they sent someone who replaced the board inside that contained all the buttons. I saw that the board was very easy to remove. He just unplugged it, and plugged in the new one. And its a very small board so probably doesn't cost much in case your monitor's warranty period has expired.
Jan 19, 2009 | BenQ FP71G 17" LCD Monitor
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
BenQ FP91G+ Problem
Hi...there,
Dies on 1 seconds usually caused by busted backlight inverter or AC Adapter if you got one on your monitor.
Nov 21, 2008 | BenQ FP91G+ 19" LCD Monitor
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
My ben t705 moniteur.... problem
I DID REPAIR A MONITOR WITH THE SAME PROBLEM. IT TURNED OUT, THAT ONE OF THE TWO HIGH TENSION GENERATORS FOR THE 2 LIGHTTUBES WAS BURNED OUT. BY REPLACING THE POWER TRANSISTORS AND THE 3 AMP. FUSE ON THE MAINBOARD THE MONITOR IS RUNNING AGAIN VERY WELL.
Nov 22, 2007 | BenQ T705 17" LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
FP567s Ver.2 ON/OFF
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 07, 2007 | BenQ FP567s 15" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
313 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
