Question about GE 21008GE2 Dual-Handset Cordless Telephone
Accidentally dropped the second handset. Wanted to check the battery, so removed it and placed in base handset. That stopped working; so removed that battery and put the original back in the base handset. NEITHER phones work now! I tested the batteries of both with my voltmeter, they both register full charge. -Dave
  • 384 Answers
There may be some kind of loose connection or short circuit .
better get it checked at service center .
Posted on Dec 29, 2010
I am unable to set handset to work with the base. Its panasonic KX-TG5933Al
Registering a handset
Important:
If you accidentally assign another
handset's extension number to the base
unit, the originally assigned handset
stops functioning. Confirm the extension
number of the handset by placing it on
the base unit or charger. Lift the handset
from the charger before registering.
1 Handset:
{MENU} i {0}{0}
2 Base unit:
Press {SELECT} until the desired
extension number (H1, H2, H3, or
H4) is displayed on the base unit, then
press and hold {CALL} until the
CHARGE indicator flashes.
LH4 can be used if you have 4
handsets.
LAfter the CHARGE indicator starts
flashing, the rest of the procedure
must be completed within 1 minute.
3 Handset:
Press {OK}, then wait until the handset
beeps.
For futher information, see the phone manual at: http://dl.owneriq.net/3/3cd5d5a0-865d-4a28-8a1f-91f144108d9d.pdf
Mar 22, 2011 | Panasonic Computers & Internet
My phone is saying "out of range" it wont let me make any calls. how can i fix it???
When the base and handset stop talking to each other, it is generally because of a power interruption. Modern cordless phones transmit a security code from handset to base, when you start a call. This helps reduce the likelihood that you and your neighbor will be talking over each other, if your phones are on the same channel. If they get out of sync, usually the phone will just beep "out of range."
  • To reset the chip which holds the security code:
    1. Place the phone back in the cradle for a slow five count. Then, pick it up and try it. If it works, you are done. If not, go to step 2.
    2. Unplug the telephone's base unit. Slide the battery cover off the handset, and remove the battery. Wait 30 seconds or so. Plug the base unit back in. Wait five seconds or so. Replace the battery in the handset. Place the handset in the base unit for a slow five count (as above). Now try it. This will almost always solve the problem.
    If this does not work, it may mean that the chip which holds your security code is now defunct and needs to be serviced. *
  • Clean the battery contacts in case the battery is not getting charged. Clean the charging contacts on your base unit with a pencil eraser. This gives just enough abrasion to rub off any oxidation, without impairing the chromed surface of the contacts.
  • If the battery is new and you are still experiencing problems, the phone will need to be services. Contact your authorized Service Center. *
Oct 16, 2010 | AT&T 5.8GHz Cordless Phone System with...
When i try to make a phone call i says "out of range" and wont let me make any calls. what can i do to fix it?
Oct 16, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
My problem is I can not phone out with my phone which is a Uniden DSS3455 it seems as if it is locked. I was changing the ringing tone when it happened I must of pressed the wrong code.
try a simple reset first. just drop the charger into the base and watch the charger light. when it flickers that has reset it. if that does not work try resetting the handset by removing the battery for about ten minutes. remember to drop it into the base after you have put the battery back in to sync it with the base. if neither of those methods work which they should... unplug the base for about ten minutes.... make sure you also unplug the phone line as well. after it has reset plug it all back in and place the handset into the base again for a few seconds
Jan 14, 2010 | Uniden Lands Phones
"out of range"
I have a GE DECT 6.0 Digital phone (silver, 2-handset model) and one of the handsets began displaying "Out of Range" and was unresponsive. We've had severe lightning around here in recent days which interfered with the digital tv reception, so I'm pretty sure that's what caused the problem. Here was what worked for me:
- unplug base unit for 15 seconds
- press "PROGRAM" button on handset
- from menu, select "HANDSET SETUP"
- from menu, select "REGISTRATION"
- handset display will prompt you to press and hold PAGE button on base unit for 5 seconds, then press "PROGRAM" button on handset
This action re-initiates the transmission between the base unit and the handset.
Jul 13, 2009 | Thomson GE 27907GE1 Cordless Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Re-registering handset ge 27851
This should work. Unplug the base power and leave unplugged or a minute or two. Plug the base back in and place the handset you want to register as handset 1 on the base and leave there for 20 seconds. If you want to register more handsets then place each one in the base for 20 seconds in the order you want them numbered. If this doesn't work you may need to remove the batteries from the handsets as well when you unplug the base. I hope this helps.
May 17, 2008 | Uniden Cordless Phone
VTech 5.8 mhz won't work
I found a solution that fixed this problem (at least for me). On the vtech site they said to unplug the base unit for at least 5 minutes. Previously, I had only unplugged the base unit for a few seconds. This time, I left it unplugged for about 10 minutes or so and when I plugged it back in, everything was working fine. Apparently there is some sort of capacitor that must discharge long enough to completely remove power from the circuitry.
Good luck and I hope this works for you!
Jan 18, 2008 | Vtech 9009111 Cordless Phone
Searching for base
My long-term experience with these phones is that occasionally, they get themselves into some kind of weird state: this is usually indicated by the flashing "searching" message.
In all cases it's been cured by unplugging the power supply AND the phone-line (both simultaneously) from the base, waiting a few seconds, then re-connecting. Normally this sorts things out, but will require you to re-set time& date (the base can sometimes still derive power from the incoming 50v line). Batteries out of handsets is a last (addtional) resort. I've very rarely had to re-register.
Jan 27, 2007 | Vtech i5871 Cordless Phone
Lost comunication
I solved this problem with a RESET of the handset. Instructions from the Philips website: Please perform a reset of your device. You will not loose your recorded data (phonebook and personal settings are being kept). 1. Unplug the mains of the base station. 2. Remove one of the batteries of each handset. 3. Put the batteries back in and re-plug the mains of the base station.
Mar 09, 2006 | Xact Communication XG2200 Cordless Phone
Lands Phones Logo
96 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
